Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-16-2008, 09:58 AM
cooploops is starting off with a positive reputation.
removing EGR etc?
ya know looking at my 77 f150 versus my 85 f150....
look to be about the same motor.
and since my truck is too old for emissions to apply in my state,
is it feasible to remove all that egr, vacuum etcetc and throw on a simple single barrel carter carb ie same configuration as the 77?
its amazing how all that extra emissions hosery and electronics makes the two engines look completely different lol
or am I way off base here?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-16-2008, 10:12 AM
fmc400's Avatar
fmc400 has a very good reputation on FTE.fmc400 has a very good reputation on FTE.fmc400 has a very good reputation on FTE.
There is no reason to remove EGR; there are no performance or mileage improvements despite all the misinformed hype. If you remove the EGR, you have to remove the vacuum advance on your distributor and replace it with an adjustable one to flatten out the timing curve and you may also have to install new springs under the breakerplate. Furthermore you will have to richen up the carburetor by re-jetting it in a toil-some trial-and-error process. At best, with a lot of tuning, you will only get back to where you started.
Anyone that tells you to remove EGR because it is sucking power from the engine is completely wrong; to date there is no reliable data that shows EGR has any noticeable effect on power. EGR also helps to cool the combustion chambers and without it you will introduce many problems with pinging and sometimes dieseling. It is a common misconception that it is "smog junk," while it was originally introduced to reduce NOx emissions by displacing a small amount of air\fuel mixture at part-throttle, it serves many more purposes than that. I agree that vacuum lines running all over your engine are not the prettiest thing, but unless you need to get rid of it because you're going to a 4 barrel intake or some other credible upgrade and you are prepared to properly tune the system as a whole, make your life easier on yourself and leave it be.
  #3 (permalink)
Old 07-16-2008, 10:40 AM
ok thanks
  #4 (permalink)
Old 07-16-2008, 01:45 PM
81-F-150-Explorer is gaining momentum as a positive member of FTE.81-F-150-Explorer is gaining momentum as a positive member of FTE.
And just to add this, A properly working EGR valve can actually increase your mileage.
Think of it this way...
The EGR introduces a small amount of exaust back into the combustion chambers.
Your cylinders are going to be the same size no matter what you do, so...
If you removed the EGR valve, what type of gas is going to replace the exaust to "fill up" the combustion chamber?
That's right, Fuel.
Don't remove any of it, unless it's defective and causing you problems. And repair is always better if you can.
Hope this helps.
  #5 (permalink)
Old 07-16-2008, 02:25 PM
Kuskoal is starting off with a positive reputation.
not to be a smart ass, but when you add the exhaust gas back into the cylinder and less air/fuel is in the cylinder... dosent that mean you would need to add more fuel to get an efficient combustion? i wouldnt know, i went 4bbl when i got this 302 and got help tuning it.
__________________
  #6 (permalink)
Old 07-16-2008, 02:30 PM
fmc400's Avatar
Kuskoal: No, it doesn't. Exhaust gas is inert in the combustion chamber and it literally displaces a set amount of the air\fuel mix. The remaining air\fuel ratio therefore remains the same. And 81-F150 is correct about what he said about mileage.
  #7 (permalink)
Old 07-16-2008, 06:38 PM
80F100man is starting off with a positive reputation.
Another thought for ya' cooploops, why fix sumthin' that aint broke??
  #8 (permalink)
Old 07-16-2008, 09:21 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
I am with the people that say don't take it off. But I do not like them either. They are just something else to break or fail, and they will break and give you problems eventually. Just by the nature of what they do, they burn out after awhile and need replaced. All that carbon and moisture from the exhaust just eats it up. And if you are having rough idle and stalling problems, the EGR is one of the components that need to be checked.
But if you have a completely stock engine, you need to keep it on there, and keep it working. If you go with a non-emissions carb setup, you can usually do away with it.
__________________
Dave F
1989 F250 XLT Diesel
  #9 (permalink)
Old 07-16-2008, 09:28 PM
spidermonkey's Avatar
spidermonkey is starting off with a positive reputation.
been there, done that on an 80 merc grand marquis 351. made a block off plate. ran like crap, AWFULL pinging under light accleration. after about a week I put the EGR back on. IMO, they're right. nothing to be gained, unless eliminating the soot from the intake passages is a "gain".
Regards,
__________________
Delray
94 F150 Supercab Flareside, 5.8, 3.73's, gt40 heads, BBK headers, Basani Y-pipe, Vortech S-Trim, Cervini Ram Air, Lowered 2/4
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
