A/C is getting cold. Nothing is in the intake area. Just really low or no air blowing from the fan. Going down the hwy @ 65 mph . When the fan does blow, its very up & down with the speed, every few seconds.
Pulled the fan out checked it, blows fine in all speed settings.
Please Help
__________________
1985 Ford L8000, Cat 3208 250K+ Miles
1989 Ford L9000, Cummins L10 500K+ Miles
1998 Ford Expo, 5.4L -235K+ Miles
1999 Ford F250, 7.3L -264K+ Miles
2003 Ford F450, 6.0L -134K+ Miles
Need to update, 255,426 miles today. I live in FL, so my AC runs wideasss Open for 9 months of the year.
Fan Spins great,
What controls the A/C, And A/C MAX. Whats the Diff on this.
__________________
Pulled the plug off the back of the fan motor, 13.8 volts there.
__________________
Does the fan blow on high when first started? If so, there is a chance your evaporator is freezing up and blocking the air. If it does not blow at all, even on heat or vent you have something wrong with the motor. I've been having to tap mine with a hammer a couple of times a year for a long time to REMIND it to spin.
__________________ Mark
Above car featured in Sept. '83 Super
Stock & Drag Illustrated. No longer mine.
1999.5 F-250 2x4 Extended Cab Long Bed
209,351+miles
6637 Mod
4 inch SS Straight Pipe
DP Oh Boy! Need I say more?
PhD In Common Sense & Logicality
University of Hard Knocks
Turned out to be the fan motor. When it ran, it was surging. Then would stop. Overheating, then come on after it cooled down. Replaced Fan Assy. Good as new.
Its hot in FL!!
Cool in my Super Duty!!!!!
__________________
