"99 F350 vacuum diagram - Ford Truck Enthusiasts Forums
Old 07-16-2008, 07:37 AM
Tony G Tony G is offline
Tony G is starting off with a positive reputation.
Anyone have a vacuum diagram for the '99 F350 with gas?
Old 07-16-2008, 08:53 AM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Assuming you want the HVAC portion (since you're in the HVAC section);
Item Part Number Description
1 18A318 Vacuum Control Motor — Panel/Defrost Door
2 18A478 Panel/Defrost Door (Full Vacuum Position)
3 — Defrost Air Flow
4 18B545 Temperature Blend Door (Full Heat Position)
5 19860 A/C Evaporator Core
6 19A813 Air Inlet Duct Door (Full Vacuum Position)
7 — Outside Air Inlet
8 18A318 Vacuum Control Motor — Air Inlet Duct Door
9 — Recirculated Air Inlet
10 19805 Blower Motor
11 18476 Heater Core
12 18A559 Floor/Panel Door (Full Vacuum Position)
13 — Floor Air Flow
14 — Vacuum Source
15 19A566 A/C Vacuum Reservoir Tank and Bracket
16 19B888 A/C-Heater Function Selector Switch
17 18A318 Vacuum Control Motor — Floor/Panel Door
18 — Panel Vent Air Flow
Old 11-23-2011, 02:15 AM
Mdennis0_8 Mdennis0_8 is offline
Mdennis0_8 is starting off with a positive reputation.
ihave a 2000 f350, the heater works, but only stays on defrost, also wont switch to A/c could it be the dail on the dash, or a bigger problem?
Old 11-23-2011, 08:21 AM
See the FAQs above....
460 Vacuum Diagram idahocrewcab Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 10 01-12-2011 02:19 PM
96 Vacuum Diagram CIGARMAN62 1987 - 1996 F150 & Larger F-Series Trucks 1 08-13-2010 02:16 PM
Vacuum Diagram for '98 F-150 skiatookbandman 1997 - 2003 F150 2 06-03-2010 08:21 AM
Need vacuum diagram for 89 F350 5.8 EFI jsimpson 1987 - 1996 F150 & Larger F-Series Trucks 5 02-18-2009 09:55 PM
vacuum diagram steve83 1987 - 1996 F150 & Larger F-Series Trucks 4 01-13-2003 05:34 AM
Tags
1997, 1999, 19a566, 99, ac, bracket, diagram, diagrams, f150, f350, ford, reservoir, tank, truck, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
