My Rochester is Whistling!
Old 07-15-2008, 10:19 PM
e-tek's Avatar
e-tek
e-tek is offline
I thought I had fixed a LOUD whistle (Vacuum leak) coming from my rebuilt Rochester in my '46 Merc (Flathead 8). It went away when I replaced and filled the Air Cleaner's Oil bath - for about a week, but now it's back.
It's a vacuum leak of some sort but I couldn't find it with a tube and trying to cover different areas, plus, I sprayed starter fluid around it but no idle changes....
Anyone heard this before or have any ideas on how better to pinpoint the leak? Thx!
Old 07-16-2008, 06:05 PM
effie_man's Avatar
effie_man
effie_man is offline
i refer to what i wrote in you other post in Man/sask forum . welcome to the flathead section where all the gods live lol
Old 07-16-2008, 07:52 PM
Kazoo's Avatar
Kazoo
Kazoo is offline
Didja check the oil level in the air cleaner?? Whatever is whistling could be suckin the oil out, maybe thats why it came back.
Old 09-06-2008, 03:55 PM
WerbyFord's Avatar
WerbyFord
WerbyFord is offline
I've had the Whistle numerous times, it has always been a bad seal at the carb base gasket to the intake. It will run ok, just whistle. If it was any worse it would behave like a vacuum leak. It was worst on one carb I had with a warped base, I'd just put up with it. Change base gaskets and check that the gasket covers everything fully, that is my bet.
Old 09-06-2008, 09:38 PM
e-tek's Avatar
e-tek
e-tek is offline
Thanks guys. I drive this truck several times a week and hadn't heard it until just today again - most of summer nothing. I'm gonna check for leaks again and add a gasket to see if that works.
dtgl90vt
06-22-2016 03:15 AM
bobj49f2
06-09-2016 12:45 AM
Irish19614x4
1999 to 2016 Super Duty
03-06-2016 08:58 PM
User 122821
03-06-2016 09:37 AM
BigAl250
01-26-2014 08:56 AM
Quick Reply: My Rochester is Whistling!
