Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > Flathead V8 and Flathead 6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-15-2008, 11:19 PM
e-tek's Avatar
e-tek e-tek is offline
e-tek is starting off with a positive reputation.
My Rochester is Whistling!
I thought I had fixed a LOUD whistle (Vacuum leak) coming from my rebuilt Rochester in my '46 Merc (Flathead 8). It went away when I replaced and filled the Air Cleaner's Oil bath - for about a week, but now it's back.
It's a vacuum leak of some sort but I couldn't find it with a tube and trying to cover different areas, plus, I sprayed starter fluid around it but no idle changes....
Anyone heard this before or have any ideas on how better to pinpoint the leak? Thx!
  #2 (permalink)
Old 07-16-2008, 07:05 PM
effie_man's Avatar
effie_man effie_man is offline
Fatty driving the Flatty!
effie_man is gaining momentum as a positive member of FTE.
i refer to what i wrote in you other post in Man/sask forum . welcome to the flathead section where all the gods live lol
__________________
Chris
53 f100 Custom Cab
04 F150 STX 4x4
  #3 (permalink)
Old 07-16-2008, 08:52 PM
Kazoo Kazoo is offline
Kazoo is starting off with a positive reputation.
Didja check the oil level in the air cleaner?? Whatever is whistling could be suckin the oil out, maybe thats why it came back.
  #4 (permalink)
Old 09-06-2008, 04:55 PM
WerbyFord WerbyFord is offline
WerbyFord is starting off with a positive reputation.
I've had the Whistle numerous times, it has always been a bad seal at the carb base gasket to the intake. It will run ok, just whistle. If it was any worse it would behave like a vacuum leak. It was worst on one carb I had with a warped base, I'd just put up with it. Change base gaskets and check that the gasket covers everything fully, that is my bet.
  #5 (permalink)
Old 09-06-2008, 10:38 PM
e-tek's Avatar
Thanks guys. I drive this truck several times a week and hadn't heard it until just today again - most of summer nothing. I'm gonna check for leaks again and add a gasket to see if that works.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
