lug pattern - Ford Truck Enthusiasts Forums
lug pattern
Old 07-15-2008, 12:21 PM
lennyluminum lennyluminum is offline
lennyluminum is starting off with a positive reputation.
lug pattern
does any one know the jug pattern for a 91' f150?
Old 07-15-2008, 12:47 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Quote:
The wheel lug pattern is 5 by 5.5", as for the other thing... it's all about personal taste.
Old 07-15-2008, 12:51 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Uh, the lug pattern is: 5 lug, 5.50" bolt circle, the same for every F150 from 1975 thru 1996.
F100's had the same bolt circle pattern: 1953/1979, also 1983.
1980/82 F100's have a 5 lug 4.50" bolt circle pattern.
btw: Is that a little brown jug, or sumtin' else?
Old 07-15-2008, 12:53 PM
Quote:
Originally Posted by NumberDummy View Post
5 lug, 5.50" bolt circle pattern, the same for every F150 from 1975 thru 1996.
what other trucks have that same pattern?
Old 07-15-2008, 12:59 PM
Which one?
Some Dodge 1/2 ton trucks, 1939/48 Ford/Merc cars, Jeeps and Chrysler Imperials (1950/56) have the 5 x 5.50" pattern, prolly others.
I've seen both on Studebaker 5R & 8R trucks, it depended on the year.
Chrysler Imperials (not regular Chrysler models, they have a 4.50' bolt circle) came with chrome wire wheels in 1953/56.
I had a set on my F100 once, but only for a few weeks. Cleaning those wire wheels was a real b!tch!
Old 07-15-2008, 01:03 PM
Which one?
Dodge 1/2 ton trucks, Jeeps and Chrysler Imperials (1950/56) have the 5 x 5.50" pattern, prolly others.
Chrysler Imperials (not regular Chrysler models, they have a 4.50' bolt circle) came with wire wheels 1953/56.
the same as my 91' f150 I want to buy new wheels for it but know one knows the lug pattern on there wheels they are selling just what truck they came off of. so if I know what other trucks and the years that have the same bolt pattern as my 91' f150 I will know where to look for wheels.
Old 07-15-2008, 01:20 PM
Here's another model I forget to mention.
1975/2001 E150 Econolines have the same 5 lug 5.50" bolt pattern as 1975/96 F150's, 1953/79 F100's used.
I don't have a parts catalog wheel reference after 2001.
Old 07-15-2008, 03:03 PM
945SPD 945SPD is offline
945SPD is starting off with a positive reputation.
Old 07-15-2008, 03:26 PM
I just wanted to know what year dodge, chevy, toyota trucks have a 5 x 5.5 bolt pattern
Old 07-15-2008, 03:38 PM
alxsnmr alxsnmr is offline
alxsnmr is gaining momentum as a positive member of FTE.
Take a tape measure with you, measure the holes and see if they will work, if not dont buy them. You can have the seller measure for you using the right methods. I have only seen the 5 lug wheels on 2wd 1/2 ton chevy trucks, just depends on the dodge truck year but I think the newer trucks have the 5x5.5".
Old 07-15-2008, 05:30 PM
Hakk Hakk is offline
Hakk is new and has a neutral reputation at this point.
What is the lug pattern on the F250?
Old 07-15-2008, 06:10 PM
northern 7.3 northern 7.3 is offline
Temporarily Deactivated
northern 7.3 is starting off with a positive reputation.
97-down 8 on 6.5" 99-up 8 on 170mm?
Old 07-15-2008, 11:45 PM
8 lug 6.50" bolt circle: 1953/97 F250 / 1967/97 F350 / 1969/74 E300; 1975/2001 * E250/350. E = Econoline.
6 lug, 7.25" bolt circle: 1953/66 F350.
*Since I don't have a Ford truck parts catalog reference inre to wheels after 2001, I don't know what Econoline wheel sizes are after that date.
Old 04-12-2009, 08:37 AM
cwilson0823 cwilson0823 is offline
cwilson0823 is starting off with a positive reputation.
Lightbulb Will 80/82 2wd rotors direct fit a 87 f150?
I am working on my 1987 f150 and want to make it a street only truck, and want change my wheels. Most of the wheels I have looked at are 5-4.50 bolt pattern. I want to know if anyone knows if the 80-82 f100 rotors will direct bolt on to my truck. I am planning to change the rear end out for an explorer unit which is slightly narrower and also moving my leaf springs inward(custom work), which will allow me to drop the truck and give a moderate pro-street look without cutting my frame. I want a custom look, lowered, but still drive stock. I plan to leave the FI 302 alone, with the cruise, but also am planning to changethe C6 out for an over drive tranny similar to the one in my 1986 Full Size Bronco.
Any suggestions?
Old 04-12-2009, 01:19 PM
Dean88's Avatar
Dean88 Dean88 is offline
Dean88 has a good reputation on FTE.Dean88 has a good reputation on FTE.
I think it the rotors will swap out, but forewarned, not all of the 80-82 F100's were the 4.5, my 1980 F100 was the 5.5 rims, so be sure to take a tape. Number Dummy can correct me, but from experience F100's with power brakes has the 5.5, F100's with manual brakes had the 4.5 rims.
5 lug pattern to new 6 lug pattern 96sherm 1997 - 2003 F150 0 04-17-2015 07:56 AM
Bolt pattern? SuperDuty93 1957 - 1960 F100 & Larger F-Series Trucks 1 05-05-2014 12:22 AM
2006 E250 wheel lug pattern? wildstang 1968-2013 Full Size Vans 0 10-30-2011 06:23 PM
2007 F-150 bolt pattern vs 07 expedition suebee68 Brakes, Steering, Suspension, Tires, & Wheels 3 11-08-2008 09:36 AM
54 F-100 lug pattern? lakecityg 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 03-11-2006 09:41 AM
Tags
12, 1969, 1983, 1997, 2001, 725, bolt, circle, f100, f250, fit, ford, lug, pattern, ton, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
