7.3 coolant flush - Page 3 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
7.3 coolant flush
  #31
Old 08-29-2010, 10:51 AM
GEugeneS GEugeneS is offline
GEugeneS is starting off with a positive reputation.
Quote:
Originally Posted by ScaldedDog View Post
Comment - If you're going to remove the passenger's side drain plug without removing the starter, and that's the right way to do it, disconnect the batteries. Otherwise, you'll shower yourself with sparks when you accidentally touch the wrench to the starter wire.
Great point, I just discovered that yesterday!
  #32
Old 08-29-2010, 10:56 AM
Quote:
Originally Posted by Stewart_H View Post
No offense, but that is NOT the right way to do it.
Removing the starter is not necessary at all, and you don't have to disconnect the batteries. If your near the starter wire, you're doing it wrong. You access the passenger side plug by going up the side (well behind the wires) and over the starter.
Properly accessed, a person is just nowhere near the starter terminals and wires.
I've done this three times now, so I'm pretty familair with the procedure, and removing the starter is just a waste of time and energyt
Another great point. There is in fact plenty of room to remove the plug and I did it yesterday three times without any problem. But the fourth time when I dropped the driver caused me a few anxious moments!
Coolant recommendations? holyspirit 1994.5 - 1997 7.3L Power Stroke Diesel 2 06-02-2015 12:23 AM
Coolant Flush eutecticpt Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 05-16-2015 09:14 AM
Goochs Flush Procedure Chevmn56 1999 - 2003 7.3L Power Stroke Diesel 0 04-25-2015 02:37 PM
Replacing Oil Cooler.. What else should I do or upgrade? ExFire Excursion - King of SUVs 1 03-05-2013 12:43 AM
7.3 diesel coolant flush ffes5 1999 to 2016 Super Duty 4 10-25-2010 09:50 PM
Tags
2000, 73, 73l, additive, coolant, dca2, drain, engine, flush, ford, interval, petcock, psd, radiator, raidator, replace
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
