Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-15-2008, 12:13 PM
fairlaniac's Avatar
fairlaniac is starting off with a positive reputation.
Window crank handle removal - how?
How do you remove the crank handle on a '05 SD XL front door?
Thanks!
__________________
Thanks,
Doug
2005 F-250 Super Duty V10/Auto 4x4 Supercab
1989 Ranger 2.3/5-Spd Supercab
1966 Fairlane 390FE/4-Spd
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-15-2008, 04:07 PM
DieselCamper01's Avatar
I am finally a...
DieselCamper01 is gaining momentum as a positive member of FTE.
Cannot help since I have power windows but here is a bump! I would assume there is a "U" shaped clip on the back side of the handle that needs to come off.
__________________
Jay
2001 F350 Lariat CC LB 4X4, MagHytech trans & rear cover, 6637, CCV, in-tank mod & filter, DiPricol pyro, trans, boost, EBPV delete, foil delete, Cryo Powerslots/front, Hawk pads, LED mod, Bilsteins, IDM mod, Fumoto
  #3 (permalink)
Old 07-15-2008, 09:16 PM
pbeering's Avatar
pbeering is starting off with a positive reputation.
You need a window crank puller. It is a U shaped flat tool. You should be able to get one at most auto parts stores.
It pushes the retaining clip off (and puts it back)
__________________
'08 F350 Super Snow Fighter
'99 F350 Super Duty
Sig edit. No commercial ads in signatures.
  #4 (permalink)
Old 07-21-2008, 04:32 PM
2002 F350V10 is starting off with a positive reputation.
WRONG!!!! The clip pertains more to GM vehicles.
On XL versions of the ford superduty without power windows, here is the procedure.
On the window roll up handle the outer black surface is actually a plastic cover clipped over the handle. Grab the sides of the handle near the door panel and unclip the cover, and then move the cover to the side. You will see that in the center is a torx headed screw you need to unscrew, and then just wiggle the handle a little and it will pop off.
To remove the door panel after the handle is off, unclip the inner mirror trimplate, unclip the small plastic piece just in front of the armrest, remove the 1 screw hidden under there, remove the lower rear door panel reflector, remove the screw hidden under the reflector, grab the door panel and slide upwards towards the sky and remove. Takes about 3 minutes. Tops.
Dont forget, when you install the crank handle, you should index it so when the windows are rolled up, it matches the position on the other side.
  #5 (permalink)
Old 07-21-2008, 06:56 PM
84deisel's Avatar
84deisel is starting off with a positive reputation.
I usally put the handle in a spot that doesn't hit my leg with the window up or down.
__________________
84 f250 4x4 deisel (sold ) 2002 f250 4x4 supercab 7.3psd auto,81 f100 4.9 auto fully restored, 96 ln8000 8.3 cummins allison 12' flink plow 10' flink ss salt spreader and way to many ford company trucks to list
  #6 (permalink)
Old 07-21-2008, 07:56 PM
fairlaniac's Avatar
2002 F350 V10,
EXCELLENT directions. I had a lower windo rattle. I had the door panel off, window track tightened and back together in less than 10 minutes. That included a few walks back and forth to the garage for tools. THANK YOU!
84deisel,
How big is your leg? My leg would need to be a foot and a half in diameter to hit the crank :-) Actually that is exactly what I did to my Fairlane. There my legs easily hit the crank.
Thanks again!
__________________
Thanks,
Doug
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
