Odd? AC stops cooling after awhile. Frost on somthing out there!
97 F-150 Lariat 5.4, 4X4, auto.
I noticed last year on a long drive, the AC stopped putting out Cold air after a long time.
It's working fine for short periods. Good n' cool.
This year I noticed the same thing, and when I had the hood up, I see this white thing out under my hood that's all frosted.
What is that? What does it mean to me and my problem?
Is this a simple fix, as in more R-134 fluid?
The evaporator is freezing up.
Usually, this is caused by a cycling switch that is not opening when it's supposed to.
What you are seeing is the accumulator that is frosted. The switch screws into a port on the top of it. There is no need to worry about the charge when changing the switch as there is a valve under the switch that prevents leakage when the switch is unscrewed.
Replace the switch, available from almost any auto parts store. Just ask for the low pressure cycling switch.
Steve
Steve
If you blindly add refrigerant to the system you could damage the compressor. If it is fully charged and you add more to try it you will then be OVERCHARGED.
IF the system was low and "freezing up" it would STILL be the low pressure switch NOT OPENING when the pressure got that low that it allowed it to freeze.
truckfella
08-27-2014 01:56 PM
Supertommy68
1999 to 2016 Super Duty
01-14-2014 04:33 PM
FX4 Fighter Pilot
15
03-09-2009 07:27 PM
jbulson
03-11-2003 07:43 PM
