I have a 91' f150 and want to swap out the dash with a 95' f150 mine is a v8 the 95 is a v6. will the dashes interchange or will it just be a super pain in the a**?
It can be made to physically fit, but part of the firewall in your 91 will have to be replaced, i think it is the area where the steering goes through.
Are you talking about the gauges or the entire dash from end to end? If the 95 gauge set includes a tach you probably will have to have a V8 tach but not positive on that because the signal comes from the computer. Also the gauge cluster is all electric where the 91 still has the speedo cable.
__________________
Stock 1978 F250 Custom regular cab 4x4 with 351M and 4 spd.
1991 Bronco silver anniversary, 5.8L EFI, E4OD swapped for C-6, otherwise still stock.
Sounds like you are trying to gain a tach?? I'm not sure IF '87-'91 had a tach option or not?? you should try & find a cluster somewhere in those years with the same # of cylinders as what you have.
If you DO NOT have a diesel you CANNOT use a tach from a DIESEL application.
my dash is fine I just wanted to but a newer one in. I have a 91 f150 and just got a 95 for parts and wanted to swap the dash out cause the 95 looks better.
Just for info. I was at one of the local yards looking for a tach cluster for my '96. I came across countless truck from that range of years with tach's in them.
__________________
Tell me I can't do it or it can't be done I will go out of my way to prove myself right.
1996 F-250 4X4 460, 3.55, e40d
1985 D-350 Not sure what engine to place in it yet
1971 F-250 Not sure what engine to place in it yet. Leaning towards a 7.3 turbo Powerstroke out of a '99 or newer F-250
