Air Pump Eliminator Kit
Alright I don't wanna hear it doesn't add performance blah, blah, blah. I've tried to bypass mine w/ a shorter belt and ended up with either too short or too long. I know they sell kits for Mustangs to eliminate the air pump. Does anyone know if they work on trucks? Mine is a '93 F-150 w/ 5.8
Please post your belt size here, so others of us that are doing the same thing can benefit as well. I'll be getting a new belt in the next couple weeks.
I just removed the smog pump from my 95 Lightning with a smog pump delete pulley from Jegs for a 87-93 Mustang. I have small underdrive crank pulley also a 97" belt was used but you have to work to get it on so a 98" would fit better.
My 2 cents.......
Jegs #778-68110 Proform brand,$55 bucks!
My 2 cents.......
I also run a shorter belt on my '95 5.0. Tried several brands at the same length and the Gates brand worked. Not sure if same belt is used on 5.8. There was a diff in length although they both said same thing on markings. I used a belt measurer to concur there is a differences in lengths amongst brands.
I'm sure you guys know this, but for those that might not:
If you eliminate the air pump, you MUST eliminate the cats.
You can have an air pump without cats, although it is a huge waste, but you cannot have cats without the air pump (on a system engineered to include an air pump).
Also, on a personal experience note:
My son and I just finished a project where we used aftermarket eliminator pullies.
One eliminator was a Ford part, the other was an aftermarket brand I don't remember this moment. They both were horrible quality. The cheap plastic pulleys wobble and squeak from the very first use. I only found out after we bought the overpriced junk that you can use numerous belt routes and lengths to accomplish any pulley elimination.
I highly recommend just googling different belt routes and lengths to accomplish your goals, rather than buying eliminators.
Edit:
If you can't find a route and belt length that suits you for whatever reason, get a taylor's measuring tape and figure out your own custom route.
So long as the ribbed side of the belt is touching ribbed pulleys and the flat side of the belt is touching smooth pulleys, everything will rotate properly. You cannot screw up a serpentine belt unless you screw up smooth side vs ribbed side.
Edit:
Edit:
Edit:
I drove my truck for quite some time with NO air pump and the factory exhaust intact (cats included). Not trying to argue, just sayin'...... Plugged the air tube coming up to the back of the engine, and ran just fine.
I got a 93 302 with no smog pump and not running the bypass pulley.
I using a cheap value craft belt from Auto Zone and it been 10,000 miles.
It only came off once last winter when it was very cold and wet out. It happen when I started the truck up. Must of frozen to one of the pulleys.
I heard the 5.8 you do not need the bypass pulley because the engine is wider and should not throw the belt.
