Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-14-2008, 02:17 PM
alphafourwheeldrive is starting off with a positive reputation.
Trans slipping after downpipe install
I have a 97 F 350 and just installed a 4" exhaust. Immediatly after the install, the transmission started upshifting hard. No problems before the exhaust install. It is more noticeable under heavy throttle. Checked fluid level and codes, everything is ok.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-14-2008, 07:17 PM
RubberDuck's Avatar
Death Row Inmate #1
RubberDuck has a very good reputation on FTE.RubberDuck has a very good reputation on FTE.RubberDuck has a very good reputation on FTE.
I can't remember, but do these trannys have a vaccum modulator on the DP side? If they do, I would bet you a dollar that you knocked that line off. That will cause it to shift hard. But I'm not sure if these trannys have that being electronic controlled and all. Just get under there and look for anything you may have bumped. Heck, Just look everywhere you touched. That doesn't make sense. Unless your tranny was dying and after the install you went out and leaned on it checking out your new mod. Double check everything. I'm sure the auto guru's will be here shortly.
By the way, Welcome to FTE! We're glad you chose us to help you with your problem. I'm certain we can help you get it ironed out. And I look forward to seeing you on the boards.
__________________
RubberDuck
1995 F350 Crew Cab 4x4 dually
DIY Stage 2's
T.E. SD HPOP
Tymar HPX
FPR 70psi
RSB Diesel 140v IDM
Tymar Intake
3"DP to 5" stacks
DP Tuner 2 pos. w/ custom switch
Hot Pedal
Gear Vendors OD
Good bye No.3 I'll miss you.
RIP #17
  #3 (permalink)
Old 07-14-2008, 08:31 PM
tjbeggs's Avatar
tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.
No vacuum modulator but there is the solenoid pack connector on the DP side. Very good change you knocked that loose or cut a wire. Check that connector and harness close. Also make sure you didn't pinch off one of the trans cooler lines that are over there.
__________________
Tim
Proud User of "The Cure"
1997 F-350 PSD Auto 257K
Tuned by Tony, Built by ME!
TDP/TW tunes
AD injectors
6.0 IC
17* HPOP
Tru-cool
The Cure
ESE Eliminator
6" stacks
4 Wh disc brakes
1/4 mile-14.59@88 MPH
Click the Picture for wiring diagrams, tech info and Pictures!
  #4 (permalink)
Old 07-14-2008, 10:19 PM
c00nhunterjoe's Avatar
c00nhunterjoe has a good reputation on FTE.c00nhunterjoe has a good reputation on FTE.
ditto with tj. find the busted wire on the solonoid pack
__________________
97 F-250, 4.10's Auto, Superchip, All mods by c00nhunterjoe's performance shop http://community.webshots.com/user/c00nhunterjoe
http://youtube.com/c00nhunterjoe
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
