2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Wont shift from park, brake lights work with pumping
Old 12-01-2011, 11:55 AM
Inkme's Avatar
Inkme
Inkme is offline
So Wife got stuck at QT today. Wont shift out of park. Thinking fuse, I went to rescue her cute *** and found the fuse to be fine.
Now I this is where i get confused...
NO brake lights initially
Pumped them fast about 5 times, got the lights and the shifter back
good till I put it back into park.
Now it repeatable. Pump hard about 5 times, then shift.
ANY ideas???? Fuse is good.
Old 12-01-2011, 10:55 PM
400 .040over's Avatar
400 .040over
400 .040over is offline
test teh brake light switch
Old 12-02-2011, 02:09 PM
pgonza2723's Avatar
pgonza2723
pgonza2723 is offline
Brake light switch would be the most obvious culprit. If you have your wife stand behind the truck when it won't shift out of park...see if the brake lights are coming on or back up the garage door and do the check.
Old 12-15-2011, 10:22 AM
pgonza2723's Avatar
pgonza2723
Been two weeks since replacing the brake light switch and so far haven't run into any more problems fyi
Old 12-15-2011, 11:02 AM
berry1234's Avatar
berry1234
berry1234 is offline
Were you having the same problem as Inkme or did you change your name?
Old 12-15-2011, 11:03 AM
pgonza2723's Avatar
pgonza2723
Same problem but updating my previous post to state my experience. Hopefully help someone down the road with the same issue.
Old 12-15-2011, 11:04 AM
berry1234's Avatar
berry1234
Ahh. Nice. How much did the switch cost and how hard was it to replace?
Old 12-15-2011, 12:02 PM
pgonza2723's Avatar
pgonza2723
Dealership didn't charge to install it...They said list was $78 ...but sold it for $40
Old 01-02-2012, 05:11 AM
cop on my back's Avatar
cop on my back
cop on my back is offline
I just had to replace my switch as well, same problem. No tools needed to replace, just twist the switch and pull it out to remove the wire harness plug. The plug is the biggest PITA, might need a pair of plyers to squeeze the tab.
Old 12-12-2012, 05:08 PM
graypatrick093's Avatar
graypatrick093
graypatrick093 is offline
2007 Eddie Bauer Expedition with power pedals. Got the part from the Ford House. $35 plus tax. Brake light switch in and out in under 2 minutes. I used a 16 penny nail and pressed the tab down and it popped right out. Works like a champ now. Thanks for the info.
Old 12-18-2012, 05:51 AM
LA FAMILIA's Avatar
LA FAMILIA
LA FAMILIA is offline
BRAKE LIGHTS NOT WORKING & WONT SHIFT OUT OF PARK.
SO I HAVE A E450 THAT THE BRAKE LIGHTS ARE NOT WORKING & FUSE IS GOOD SO IM TOLD 2 REPLACE BRAKE SWITCH ON PEDDLE & STILL CAINT SHIFT OUT OF PARK IT HAS THIS INTEL LOCK SYSTEM THAT I WAS THINKING OF A WAY OF BYPASSING DOES ANYONE HAVE ANY IDEALS
FordTruckChuck
1997 - 2003 F150
02-13-2016 04:21 PM
jfowler1
12-31-2015 08:23 AM
duggyb
11-24-2014 04:51 PM
littlewad
1983 - 2012 Ranger & B-Series
06-11-2012 12:31 PM
66BlackCat
Aerostar
10-03-2010 04:38 PM
Quick Reply: Wont shift from park, brake lights work with pumping
