Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-14-2008, 09:55 AM
seayya's Avatar
seayya is starting off with a positive reputation.
Can't turn the steering wheel sitting still
I have a 01 F250 4X4 CC with 315/75/16 and if you are not moving you CAN NOT turn the steering wheel. Now if I am on gravel or really loose dirt I can with some ease, but on pavement FORGET IT. You have to be moving to turn the wheel at all. It has been this way since I bought it last summer. I have no pump noise and it is full of PS fluid.
Is this normal? This sucks when you are in a tight parking lot or trying to back up a trailer. Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-14-2008, 10:08 AM
miller_feed's Avatar
Hook it, I'll pull it.
miller_feed is a splendid one to beholdmiller_feed is a splendid one to beholdmiller_feed is a splendid one to beholdmiller_feed is a splendid one to beholdmiller_feed is a splendid one to beholdmiller_feed is a splendid one to beholdmiller_feed is a splendid one to behold
Look at your fluid again. These powersteering pumps take ATF fluid. They also power the power brakes. If you have PS fluid in the pump, flush it with the correct fluid.
__________________
RICK, PAA MEMBER #4
2001, F-350, DRW. CC. LWB, 4X4, LARIAT,
MODS: 6637 W/Pete's filter cover, BTS-VB, DP-TUNER- stock, 40t, 60t, 80e, 140s, HI, OBA, 203*, billet housing, IH bolts, MBRP 4" SS, Isspro 3 gauge kit, Zoodad, Foil delete, TN-BB turbo, Bellowed up pipes, HPX, TRU-COOL cooler. For now.
Jim, Roland, Will, JD? I want to go somewhere.
  #3 (permalink)
Old 07-14-2008, 10:12 AM
Powerstrokedlariat's Avatar
Margaritaville
Powerstrokedlariat is gaining momentum as a positive member of FTE.Powerstrokedlariat is gaining momentum as a positive member of FTE.
mine is the same, been that way since I put on the 35's. I hate it too.
__________________
Brent
Redneck nail pounder and
2001 F-250 Lariat EC LB, Auto
4'' Straight Pipe, WW, Factory Tech VB,
6637, Foil Delete, Zoo-Dad, Predator, ss h.p.x.
Leveled out rolling on 35'' Nittos, Firestone bags
Quote:
Originally Posted by BabyBunny View Post
Brent.. Just face it.. You ARE the devil!!
  #4 (permalink)
Old 07-14-2008, 10:14 AM
HKusp's Avatar
Hates Liberal Pansies
HKusp has a great reputation on FTE.HKusp has a great reputation on FTE.HKusp has a great reputation on FTE.HKusp has a great reputation on FTE.HKusp has a great reputation on FTE.
Try changing to synthetic ATF. I switched to mobil1 synthetic and it helped smooth mine out a lot and it takes much less effort than it did with non synthetic in it.
__________________
-Jason PAA Member #3
I'll keep my freedom, my religion, my guns, and my money.
You can keep THE CHANGE.
7.3 helper page
  #5 (permalink)
Old 07-14-2008, 11:09 AM
seayya's Avatar
Yea, its full, but now what its full with I do not know. I will change to synthetic ATF to see if that will help me out. I just can't believe that the 315's could make that BIG of a difference over stock size. Sitting on pavement in gear or not I can take both hands and still can not turn the wheel no more than 1/4 turn in any direction. I feel sorry for anyone with 37's or bigger. Thanks again.
  #6 (permalink)
Old 07-14-2008, 11:15 AM
gofast51004's Avatar
gofast51004 is starting off with a positive reputation.
My truck has always been hard to turn while sitting still. Ever since I picked her up new at the dealer.....never gotten any worse or better. I can usually let my foot off the brake and roll a little bit while I turn the wheel to get me out of tight spots.
__________________
ben
2000, F250 PSD, 140,000 miles, all but 11 miles are mine......
6637
4" ss Magnaflow
Bilstien shocks
ISSPRO gauges
Foil Delete
'08 Diff cover
DP tuner sitting on shelf, waiting for truck to get back from the body shop after being T boned.
2006 Hummer H3 (the wife's ride)
  #7 (permalink)
Old 07-14-2008, 11:36 AM
randomhero1172 is gaining momentum as a positive member of FTE.randomhero1172 is gaining momentum as a positive member of FTE.
Quote:
Ya same here. It turns like a true truck! Wow i have always put PS fluid in ... never new about the ATF. thats so odd. Well reps for something new learned!
__________________
- Joe
2002 f-250 CC long bed 7.3 PSD - 295,000mi: 6637, Zoodad, Foil Delete,Silverstar Ultras, CCV, 5" MKO Strait Pipe, Cab Lights, WW.
NEW!!!! - 1990 f-350 dually 7.3 IDI 12ft Alum. Boc. 197,000. A little shaky
  #8 (permalink)
Old 07-14-2008, 12:26 PM
HKusp's Avatar
Joe, you didn't notice that the fluid was red?
__________________
7.3 helper page
  #9 (permalink)
Yukon is starting off with a positive reputation.
Mine is the same and it drives me nuts. What I have read in here is that the PS and PB work off from a system (sorry I don't know what it is but someone will) that needs RPM's to build up pressure to get enough power to move them while standing still. I hope someone can give you a little better info. I have just learned to live with it and park in the "back 40".
__________________
2000 SD CC PSD Lariat 4x4
2005 EXPEDITION XLT 4x4
  #10 (permalink)
Old 07-14-2008, 12:36 PM
seayya's Avatar
I have tried the revving up the engine while sitting still, but it didn't help me out any. Plus doing that is kinda embarrassing say when you are at church or other quite places. Love the muffler delete.
  #11 (permalink)
Old 07-14-2008, 01:18 PM
weekendwarriorfsw32's Avatar
PSD ALL THE WAY
weekendwarriorfsw32 has a very good reputation on FTE.weekendwarriorfsw32 has a very good reputation on FTE.weekendwarriorfsw32 has a very good reputation on FTE.weekendwarriorfsw32 has a very good reputation on FTE.
Well a few month ago mine did the same thing and I replaced the P/S pump and all is good again!
__________________
-Nick
Worlds Youngest Power Stroker
PAA#9
04 X 6.0
01 X 7.3
6637, 05 head lights, MBRP 4in Exhaust, Running boardlights, Cab lights, Dipricol Gauges, Dp tuner , Powerslot rotors and Hawk LTS Pads, OBA, WW
Quote:
Originally Posted by liftedgrocerygetter View Post
I am younger than you and I hurt all the time.. I am just a whimp though
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
