Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #46 (permalink)
Old 07-20-2008, 07:13 AM
fonefiddy is starting off with a positive reputation.
Personally, If I had 32K to spend on mods, I'd get either a PSD, or a Cummins.
Theres' a tune available for the 6.4 that gets you into the 1000 LbFt range!
The IH IDI's are just not the best starting point for enormous power/torque.
But they are extremely reliable, easily maintained, hard working engines
__________________
93 F One Fiddy- 5.0/AOD/3.55 230K OEM
93 F Two Fiddy Scab- 7.3/ZF5/3.55/Sidewinder II,94 Turbo pump,G Inj's, Velvet Ride, Ride Rite Rear, Turbo Bumper, Alcoa's
85 F Two Fiddy-6.9/C6/3.54/ Holley Red, Racor, Soup Bowl,AutoJet 3",Ride Rite Rear
Sponsored Links
To remove this ad, register today!
  #47 (permalink)
Old 07-20-2008, 08:24 AM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.
If you hold a main bearing cap in your hand you will see what I am saying, those things are massive.
I think Ken was actually causing the block to flex which is what caused his engine failure.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #48 (permalink)
Old 07-20-2008, 12:38 PM
David85's Avatar
David85 is gaining momentum as a positive member of FTE.
Maybe these pictures can give you a better idea (cylinder bores are 4", so looking at this, the main caps are at least 1" thick and I'm guessing they weighted over 1 kg each). I haven't seen the bottom end of a powerstroke, but this is just massive, they fill the clearance in the oil pan almost completely.
A powerstroke conversion would a challenge to say the least. I would never do it even if it were for some one else. By the mid 1990s trucks were highly integrated operating systems and retrofitting such a computer integrated engine into an older chassis would require a lot more thinking outside the box than I think it would be worth. The 6.4L........I won't say what I really think about that guzzler......
I would consider a cummins 12V, but since I can already get the results out of my 6.9 without sacrificing reliability or fuel economy, I just don't see the point.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #49 (permalink)
Old 07-20-2008, 10:04 PM
The DPF Delete gets the 6.4 right back into the 20MPG range.
__________________
  #50 (permalink)
Old 07-20-2008, 11:42 PM
David85's Avatar
Quote:
How do you get around the emissions police?
__________________
  #51 (permalink)
Old 07-21-2008, 04:01 AM
Dodge/Cummins is starting off with a positive reputation.
Some places there really are none but I'm sure it's illegal everywhere to remove the particulate filter.
Extremely smart but illegal.
Obviously I'm a Cummins guy but I would be REALLY interested to know how good the 6.4 PSD is without all the "nannies".
  #52 (permalink)
Old 07-24-2008, 01:57 PM
snowman84 is starting off with a positive reputation.
Wat people dont know dont hurt them. LOL
__________________
Just cause it smokes......Dont mean its Broke!!
1994 F-350 XL Reg Cab Long Box, 4x4, 7.3L IDI, 5-SPD. Custom intake w/ 4-1/2inch Cowl hood, Turned up Fuel, advanced timing, Dual 2-1/2 Exh. to single 4inch to Dual 5inch Stacks!!
Dyno'd: 150HP@2980rpm and 320LBS/FT@1890rpm!!
  #53 (permalink)
Old 07-24-2008, 01:59 PM
I personally would like to drive and see wat one would do in stock trim?? Ive only heard stuff about them..
__________________
  #54 (permalink)
Old 07-24-2008, 07:16 PM
Quote:
Amen! Cut it off/out!
Then the computer will probably go into convulsions though.
  #55 (permalink)
Old 07-27-2008, 06:16 PM
FORD MEGA CAB!!! is starting off with a positive reputation.
Out here in oklahoma we don't have emissions testing so I would think as long as no one was really bragging about it or a shop was advertising it, there would be no problem unless someone was to move out of state. I have heard that they want to bring emissions testing back here to oklahoma but that has been at least 2 years since I last heard that. depending on where you live, I would cut it out but definatly save it just in case they bring it back. Im sure thats not a cheap pice to replace.
__________________
LOADED LIKE A FRIGHT TRAIN, FLYING LIKE A JET PLANE.
1993 Ford Mega cab long bed dually diesel 7.3 IDI w/Banks sidewinder Kit, e40d w/4:10s
1995 chevy K1500 4x4 350 4l60e
1990 suzuki sidekick 4x4
  #56 (permalink)
Old 07-28-2008, 01:52 PM
No those things are wicked expensive!! I work on the big diesels and one of those DPF (roughly, it depends on the truck.) Cost around 5000 or so. Tats wat the parts guy was mentioning. But in one of the Diesel Power mags. there is a company tat makes the DPF Delete Kit. It says how much of an increase you get. But idont remember the numbers.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
