y-pipe
y-pipe
Hello to all. I am getting ready to have my up pipes changed and the ford mechanic I was talking to said I should also get a y-pipe because more than likely the bolts will break off. Does anyone have suggestions where I could pick up one. He said the dealers are way back ordered. Or if anyone has a shop they would recomend I would appreciate it. I forgot, I have a 2000 PSD.
Thanks
Roger
Thanks
Roger
Received 3,648 Likes
on
Diesel Engine Repair Scottsdale Arizona, Cummins Diesel is a great place to call and ask, they're located out in Scottsdale, and can probably get your part if it's in town anywhere! Talk to Nate or Mike there
Roger....the more I think about it, the more it bugs me and I had to do a follow up post. I see absolutely NO REASON why you need to replace your Y pipe when it's not broken yet. I'm wondering if this mechanic doesnt have the proper tools, and has broken those bolts off in the past while trying to replace up-pipes. With the right tools, there is no reason you shouldn't be able to keep what you've got to work with the new uppies. Have you had this mechanic do work before for you? I suggest ya call Mike or Nate at Strictly and pick their brain a bit about this......they are the experts. Good luck, and let us know what happens!
Thanks
Roger
Thanks
Roger
its a good idea to have a back up part...if it breaks, you put the part in, if not, send it back
if it breaks and there is no back up part...the truck could sit idle for months waiting for one
a matter of better safe than sorry...but a little penetrating fluid and some tlc...the bolts shouldnt break
