We have a 1991 F-350 with a 5.8L V8 with automatic transmission at work. It will usually start fine when it is cold but after it has been running for a bit and you go to restart it it will crank slowly, almost like a dead battery.
Here is a list of things I have checked:
* Battery is fine. I swapped with another good battery and there was no difference. Also, the voltage drop is only down to about 10 volts when trying to start.
* All cables are fine. Played around with booster cables and it still did it.
* Replaced the starter twice with 2 different ones (from different stores)
* No binding from alternator, smog pump, etc. Unhooked the serpentine belt to see.
* Solenoid is fine. Bypassed it when checking cables.
So, what else do I need to check? Truck runs perfect after it starts. It has about 200,000 MILES on it.
-Matt
