Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-13-2008, 05:49 PM
pdx02's Avatar
pdx02 is starting off with a positive reputation.
Wires through firewall
What is the best location to run wires through the firewall?
__________________
2002 Excursion. 4" MBRP exhaust. AFE stage 2 w/ pro guard air intake. 35" Toyo M/T & 20" AR Thug w/ Teflon Coating. Fossil Free Fuel 3 Tank Veg System
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-13-2008, 06:26 PM
wcurtis's Avatar
wcurtis is starting off with a positive reputation.
There are 4 wires that Ford put through the fire wall, At least on my 01 superduty, look under the hood by the brake master cylander
If you hook on to them it makes life a lot easyer
__________________
2001 f250 SCAB 5.4 2WD LB
16 ft lowe bass bost
30ft aerolite travel trailer
Big Blue
  #3 (permalink)
Old 07-13-2008, 06:28 PM
Chuck Sowa is starting off with a positive reputation.
As high as possible to keep water out also make sure to use grommets around wires to keep them from beeing cut by firewall. To seal the hole use Permatex.
  #4 (permalink)
Old 07-13-2008, 06:58 PM
weekendwarriorfsw32's Avatar
PSD ALL THE WAY
weekendwarriorfsw32 has a very good reputation on FTE.weekendwarriorfsw32 has a very good reputation on FTE.weekendwarriorfsw32 has a very good reputation on FTE.
Check my Galley under Gauge install and you can see where I ran my Gauge wires threw.
__________________
-Nick
Worlds Youngest Power Stroker
PAA#9
04 X 6.0
08 mirrors, 2 1/2 inch trailer hitch receiver, Fire stone air bags
01 X 7.3
6637 air filter mod, 05 head lights, MBRP 4 inch Exhaust, Running boardlights, Cab lights, Dipricol Gauges Boost, Pryo, Trans, Dp tuner 80E, 60 Decel, 80t, 140s, HI, Powerslot rotors and Hawk LTS Pads, OBA, WW
  #5 (permalink)
Old 07-13-2008, 10:50 PM
armydude is starting off with a positive reputation.
on my 04 i used the clutch hole delete cover. worked great. i ran 2 4 ga wires, 8 strobe wires, 6 light wires and only used 1/3 of it.
ian
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
