I just got this manifold all bolted in what goes in the hole right behind the water inlet? and what goes in the hole right behind the carb on the same side.. thanks... i have the water temp sensor on the front jole across from the water inlet...
Use the back hole for a vacuum source for a vacuum guage. Don't use it for a PCV valve. Plug the front hole and use teflon tape on the threads also to prevent leaks.
