Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-13-2008, 08:38 AM
HeavyTow is starting off with a positive reputation.
Question Fuel Gauge Troubles
I'm researching 2005 F250 that appears to only have one problem. The fuel gauge has a history of trouble. The truck has been to the shop three times and came back working three times. The sending unit was replaced twice and was listed as having a rusted sending unit once. TSB 061311 was performed once. Once again the fuel gauge is not working properly. Upon fill up the gauge will not register more than about 1/2 tank. After driving it some it will register more, but never full. Is there a frequent problem with sending units? Any ideas as to a permanent fix for this problem? Thanks in advance for any input.
HeavyTow
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-13-2008, 10:35 AM
danocross is starting off with a positive reputation.
Heavy, the dealerships here in Tucson put me through many visits and bottles of Techron before finally replacing the instrument cluster...which immediately solved a problem that went on for almost 2 years. My problem was a little different, the fuel gauge would just drop to zero randomly, sometimes staying there, or not register full right after a fillup. But it sounds like all the other things have been replaced or dealt with, then look to the instrument panel.
  #3 (permalink)
Old 07-13-2008, 11:42 AM
danocross, thanks for the tip. The work will be on my nickel so I'm trying to avoid any trips to the dealer.
HeavyTow
  #4 (permalink)
Old 07-13-2008, 03:44 PM
BigGeo's Avatar
BigGeo is starting off with a positive reputation.
Fuel Low Light
I was getting close to empty and noticed the fuel pump light by the fuel guage. Never did run out having found a station selling Diesel, close though had between one to two gallons left when I filled up. The light never did go out or maybe it is alwas lit when the lights are on and I never noticed it before. Is there a method to get it to do so or do I have a problem. Mine is an 07. Didn't mean to hijack your thread. My problem fit the title.
George
  #5 (permalink)
Old 07-14-2008, 07:27 AM
I'm not sure. On other trucks I have, when the light stays on from a trouble code I can disconnect the battery & the loss of power will make the light go out. However, on the PSD it may not be as simple as that. The two battery combination has to be handled properly and a diagnostic tool may be required to turn off the light safely. On earlier model F150s, if you packed in the fuel on fillup, it would create a code/light that had to be cleared by Ford for a fee or by a diagnostic tool. Even with all that said I wouldn't think a low fuel light would require these kind of steps. I'm sure their are some really sharp folks somewhere on the site with the real answer.
HeavyTow
  #6 (permalink)
Old 07-14-2008, 11:16 AM
BigGeo's Avatar
HeavyTow
Quote:
HeavyTow
Thanks for the reply.
I think I'll go by the dealer and ask. Getting lazy in my old age. Need an oil change anyway.
George
  #7 (permalink)
Old 07-14-2008, 01:58 PM
BigGeo's Avatar
Problem solved
Guess the light goes away after a few restarts. When I started it this morning it was off.
George
  #8 (permalink)
Old 07-14-2008, 08:08 PM
George, I have heard that sometimes that is the case, but the trouble code is still stored in the computer for a certain amount of time. Let me know what the dealer says if you don't mind.
HeavyTow
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
