Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered Bonus Built, Classic and Box Style Ford Trucks
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-13-2008, 08:18 AM
e william's Avatar
e william is starting off with a positive reputation.
Alternative Dizzy Vaccume Source?
Hi All,
Been running well ('54 239 Y with 55 merc dizzy\points) but hearing some valve noise\chatter upon acceleration. I installed the pertronics kit and set timing but could see no vaccume advance change with the timing light when I plugged the vaccume line back to dizzy. Apparently there is no vaccume coming from the rear port on the carb (holly Ford script 94).
I have already rebuilt the carb and all else works great, other than tearing down to see if vaccume port is plugged...can I use another source of vaccume (intake) for the dizzy or would it be too much constant vaccume?
I'm thinking it has to be the carb source but I also know alot of you have come up with some interesting solutions.
Thanks for any input!
Ed
__________________
What Mama Don't Know....Keeps Daddy Out Of Trouble !!!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-13-2008, 10:42 AM
56efffie's Avatar
56efffie is starting off with a positive reputation.
You may have already done this, but I would rule out the hose as the culprit first. If you pull the hose off at the carb side and suck on it and hold with your tongue the the dizzy should advance and hold, if not your hose may be bad. Not sure if you can see this with the petronix ignition?
__________________
-Shane-
1956 f100-Custom Cab
2002 f150 Supercrew 4X4
  #3 (permalink)
Old 07-13-2008, 10:58 AM
ALBUQ F-1's Avatar
ALBUQ F-1 is gaining momentum as a positive member of FTE.
nope, there is no other source that will work correctly.
__________________
Ross
1952 F-1 Flat V8 3-on-the-tree
MSD dizzy, 2110 Holley, Red's Headers
  #4 (permalink)
Old 07-13-2008, 11:12 AM
Oz52F1's Avatar
Oz52F1 is starting off with a positive reputation.
Vacuum sources really SUCK !!!!
__________________
If them thar Rednecks had had MY Clevo.....Forest woulda been finished right there!!!
  #5 (permalink)
Old 07-13-2008, 11:32 AM
havi's Avatar
Starting over IS my style
havi is gaining momentum as a positive member of FTE.
Another thought is to look at the dizzy itself and make sure there is no wear, or the advance spring is "off".
__________________
"We are holding our own."--Ernest McSorley
The Good1948 F1: Flattie on the stand
The Bad1987 TC: Test fitting drivetrain
And the Ugly1962 Fairlane: Out in the cold
  #6 (permalink)
Old 07-13-2008, 08:16 PM
e william's Avatar
I'll check the dizzy with a vaccume pull tonight to see if things change, hose is new, carb is old but rebuilt...dizzy came fron so. Cal. shop as rebuilt but I uess you never know. The only tell while driving was the mechanical noise upon acceleration. You can get away with a little more on these old trucks. I rechecked the timing after the pertronics install and it was a little advanced due to install so I adjusted it back to where it should be. I'll check vaccume advance on dizzy, recheck hose and possible the carb tonight....tomorrow I'll readjust the mixture screws on the carb as well. My book calls for apx. 400 rpm's at midle but I like it more around 600 rpm's.
thanks for the input\replies.
Later, Ed
__________________
  #7 (permalink)
Old 07-14-2008, 07:40 PM
e william's Avatar
Update......Good To Go!
Went thru the checks, dizzy vaccume held, hose was good, reading up on carb I saw that the vaccume doesnt show at curb idle...only as rpm's increase due to the spark advance control in the carb.
Check with timing light as I increased the rpm's....advance works well.
Re-adjusted the fuel mix screws with throttle at apx. 1100 rpms until a smoother idle was heard and there was no lean drop, then readjusted the curb idle to apx. 575 rpms.....she's sounding better than ever now.....I hope the pertronics holds up well over time....well see.
thanks for the input, Ed
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
