Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 07-15-2008, 09:47 PM
mstngmikegt's Avatar
mstngmikegt is starting off with a positive reputation.
I should have phrased it differently. Actually, I did as 12sec is suggesting and swapped the cluster into my truck from another 95 after switching in my speedo section because the wiring (tape or whatever it is) is all different between a tach and non tach cluster. Took the opportunity to replace about a half dozen bulbs while at it and it worked great. Better yet, I bought the tach cluster for 40 bucks, did the swap, put my original back together with the other PSOM and sold it to a guy with a bad one for 50! He's happy now his works, didn't care about a tach in his truck anyway and I got paid 10 for putting one in mine. Not a bad deal. BTW the links alz put up are good source for info on switching out your PSOM. Good luck and good to see so many Mustang guys here!
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 07-15-2008, 11:17 PM
rossijd's Avatar
rossijd is starting off with a positive reputation.
Quote:
Originally Posted by TexasGuy001 View Post
Hey rossijd, Why not put the L suspension under your 96? A friend of mine has a green 96 F150 that is a Lightning clone. It has the springs on it. You could even take the sway bars etc off of it and put them in your newer truck. If its a regular cab you could swap the seats too.
I swapped the interior in not long after I bought the truck, from the carpet to the headliner, dash and all. It has been my plan all along to use the L suspension. I have just been a while getting around to doing it. I have been spending all my time (and money) on my stang. The only thing about the suspension is that the first gen Lightnings ride so rough (I have owned 3 of them over the years). Sure do handle good though. Not sure if it is the same truck your talking about, but there is a green 96 clone in the photo gallery on this site that is just awsome. That is pretty much what I have planned for my truck, mine is white though.
  #18 (permalink)
Old 07-15-2008, 11:32 PM
rossijd's Avatar
Quote:
Originally Posted by 12secondstang View Post
Ross, I know the car you are talking about. I have a pic of my stang in my gallery. I work for Wegmans and spent 6 of my 22 years with them in the Canandaigua store. Man, 22 years and I'm not even 40.
As far as your tach. The 92-93 cluster will not allow system to charge as you found out. It happens to a lot of people here on the forums. I the 93 cluster Black face? If so, just get a 96 Cluster and put in the center speedo section into the 96 cluster. It will the look and work fine for you.
It is possible to make the 93 cluster work but that requires soldering and/or re-pinning the board and harness. I have never gotten that ambitious but some folks on the forum have done it.
Small world aint it! I'll be spending a week in Canandaigua in Sept. My dad still lives there.
I will grab a 96 cluster with tach if I run across one. I don't have the patience for all that soldering/re-pinning etc.
  #19 (permalink)
Old 07-15-2008, 11:38 PM
rossijd's Avatar
Quote:
Hey, what better reason to have a Ford truck, than to pull your Mustang around. Its great to drive your car an hour to the track, run a decent time, then drive it home. However, it really sucks to drive your car an hour to the track, break and axle, and try to figure out how your going to get home.
  #20 (permalink)
Old 07-16-2008, 01:47 AM
jarod17's Avatar
jarod17 is starting off with a positive reputation.
If you have the entire axle including the PSOM you should not have to recalibrate as the PSOM in the axle is already calibrated for that gearing and tire size. Unless you change something.
Alz, lowering your gear ratio (numerically higher) will not increase your mileage. just the opposite.
For the cluster swap. I took my stock non-tach cluster out of my '96 and put a stock cluster with tach in out of a '97. The site that describes how to do this was posted earlier. The reason that the '97 cluster worked may be from the truck being an "early" (Feb. '97) year truck. Don't know, just my opinion. Don't care either cause it is working great. no problems.
__________________
Jeff
Tell me I can't do it or it can't be done I will go out of my way to prove myself right.
1996 F-250 4X4 460, 3.55, e40d
1985 D-350 Not sure what engine to place in it yet
1971 F-250 Not sure what engine to place in it yet. Leaning towards a 7.3 turbo Powerstroke out of a '99 or newer F-250
  #21 (permalink)
Old 07-16-2008, 09:17 PM
rossijd's Avatar
Your 96 is a 250 right? The 96 and 97 250, 350, etc. were same body style. 96 and 97 150's were totally different. I guess a cluster from a "heavier" 97 might work in my truck. Not sure if many 250 and up trucks had 302's in them or not. Or would engine size not matter?
  #22 (permalink)
Old 07-16-2008, 09:33 PM
12secondstang's Avatar
12secondstang is starting off with a positive reputation.
So long as its a gas engine it will be ok.
__________________
(sold)'96 F150 Eddie Bauer 4X2 5.0 Manual(pics in gallery)
'95 F150 XLT Supercab 4X2 5.0 Auto
'85 Mustang GT 11.91 @ 116 N/A 306 Street Driven(see timeslip)
'85 GT 5 speed. 100% stock but not for long. 11 second goal with GT40p heads and N/A.
MOMSRACING D.O.T. Tire Champ '01 '02 '03
MOMSracing.com(Mustang On Mustang)
  #23 (permalink)
Old 07-16-2008, 11:33 PM
12sec is right...cluster I put in my 302 F150 was actually from a same year 300-6 F250...as long as it is gas you're fine.
Oh, jarod17...what gearing (up or down) will do for MPG depends on the vehicle combo...my Mustang actually improved by a couple on the road when I swapped in 3.55's (some 15+ yrs ago) vs the stock 2.73's. Definitely not the reason I did it, but nice side benefit especially now that gas prices are nuts!
  #24 (permalink)
Old 07-17-2008, 05:47 AM
jarod17's Avatar
That is being debated right now. I am getting ready to get a crash course in differentials soon and do an experiment on my truck when I get some extra money. I will keep posted either with this thread or my other thread http://www.ford-trucks.com/forums/73...l-mileage.html
__________________
Jeff
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
