Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-12-2008, 09:56 PM
Bruteforce1974 is starting off with a positive reputation.
The right cam?
So im doing research tryin to figure out what i want to do with my 84 fox im planning a 347 and im going to run a 150 shot of nitrous i would like 400hp with out it though! but i have 2 questions im not sure about 1. What heads work good in this situation and are they affordable? 2. What would be a good cam for this set up i just read an article on the new comp cams big mutha thumper which would sound sick and they compared it with some other proven cams and it seemed to put out power as well as sound really nice? PLease help!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-13-2008, 12:38 AM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
Are you going to run a flat tappet cam or Hyd. roller? TF Twisted Wedge heads will allow 2.02 valves without piston mods(except 86 models with no valve reliefs) or you can use the GT40 X heads. The Trick Flow TW set-up for EFI on a 306ci is good for 360hp.
Are you going to run a carb set-up?
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #3 (permalink)
Old 07-13-2008, 02:59 AM
yea man i want to go with a full roller set up and its on an 84 so im going to keep it carbed for sure plus i heard alot of good things about the twisted wedge heads ill have to do more research i leave in the morning for texas for like three weeks so ill get back to you as soon as i get to a computer thanks for your help!
  #4 (permalink)
Old 07-13-2008, 05:37 AM
LxMan1's Avatar
Edelbrock RPM intake with a 625 Demon carb, TFS twisted wedge heads, CompCams 286R
COMP Cams: Ford 5.0 Magnum 286HR Cam
with matching valvetrain.
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #5 (permalink)
Old 07-13-2008, 07:25 AM
sounds good thank you!
  #6 (permalink)
Old 07-13-2008, 11:47 AM
BaronVonAutomatc is starting off with a positive reputation.
AFR, baby, AFR.
I thought you needed special pistons to run TW heads because of the different valve angles and 2.02 valves. Notching for valve clearance is something to keep in mind if you buy heads with 2.02 valves.
If you're planning to drive it on the street at all, AFR165 heads. If it's a strip car get the AFR185 heads.
Small Block Ford Dyno Results: Aluminum cylinder head manufacturing and flow dynamics
Some dyno results and build specs. 421hp from a 302 with a radical, but streetable, roller cam and AFR165 heads...so you'll fall a$$ backwards into 400hp with a 347.
All the Comp XE cams rock and I've heard the Thumpr's are pretty strong too. If it's a street car buy less cam than you think you want (~270* for flat tappet or 280* for a roller). Start with a later model roller block and go roller if you're building it from scratch.
__________________
1986 Bronco w/300 I6 & ZF 5-Speed
1982 F250 4x4 w/302 & C6
  #7 (permalink)
Old 07-14-2008, 06:55 AM
LxMan1's Avatar
No, with the TFS TW heads, you do not need to notch the pistons more like you do with all other heads to run bigger than a 1.94 intake valve.
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #8 (permalink)
Old 08-03-2008, 06:09 PM
whats the problem with running the bigger heads on the street i thought it was the bigger the better!
  #9 (permalink)
Old 08-03-2008, 10:29 PM
JBradley500 is starting off with a positive reputation.
the bigger it is, the more CI or RPMs you need to get the power. not to mention a different cam with less streetable manners.
__________________
New Plan...
410ci, 10:1, AFD 57cc 2v Heads, Edelbrock Intake and Phenolic Spacer, 725 cfm Road Demon, Roller 219/222 @.050 .535 lift 108 lsa, Bee-Hives, Dual Roller Chain, ARP's, MSD Pro Billet, Hedman Headers, Milodon Pan and HV Water Pump.
  #10 (permalink)
Old 08-09-2008, 09:05 PM
thats pretty much what i have been seeing to now my question is this roller cam set ups are spendy and flat tappet is more afford could i still get 400 horse with a flat tappet or should i spend the extra bucks on the roller cam!
  #11 (permalink)
Old 08-10-2008, 11:21 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
A flat tappet will make as much HP as a roller given roughly the same lift and duration, so there's no need to spend the extra $$ on a roller conversion from a strictly performance point of view.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, Roller Rockers, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, sliding rear window.
  #12 (permalink)
Old 08-10-2008, 03:33 PM
[quote=BaronVonAutomatc;6343634]AFR, baby, AFR.
what is bad about running the 185cc heads on the street? i was looking at the heads but the 185cc heads are not that much different as far as flow it is an increase but im not sure why it would be a problem also i was reading up on Patriot-performace.com and RacingHeadsService.com does anybody know anything about those companys products!
  #13 (permalink)
Old 08-10-2008, 03:48 PM
i wouldnt buy patriots or RHS before AFR. they are both budget heads. i would get RHS before the pats.
__________________
New Plan...
  #14 (permalink)
Old 08-10-2008, 03:54 PM
yea thats what im thinking but its all going to come down to my budget but im curious what isnt good about the patriots and i was looking at the rhs and they have impressive flow numbers is it just a durablilty issuse?
  #15 (permalink)
Old 08-10-2008, 04:30 PM
patriots use old used castings on their iron heads that they buy from customers like you. they dont use new. they will not flow what it says on the internet. they also have had past troubles with valve guides because of loose tolerances being allowed at the factory.
RHS is owned by comp cams. i dont know if they use new castings or not for their cast iron heads. i dont know much about these heads to really say.
__________________
New Plan...
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
