Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-12-2008, 08:10 PM
frederic's Avatar
frederic has a great reputation on FTE.frederic has a great reputation on FTE.frederic has a great reputation on FTE.frederic has a great reputation on FTE.frederic has a great reputation on FTE.
Leaf Spring Perches?
Like most F-series of our vintage, occasionally I am plagued with rust-related issues.
Driver's side rear leaf spring perch - two complete pieces and what's left will fall off if I sneeze near it.
Passenger side rear leaf spring perch - one piece still but there's about 1/4" square piece of perch left between the upper and lower portions that are remaining, so a hard stop or a pothole will make it much like the other side.
After lots of googling, I'm struggling to find replacements for some reason. I would have thought it to be easier.
None-the-less, I have a 93 2wd F350 crewcab, SRW, and it has 3" wide rear leaf springs (which I imagine to be the most important specification).
Any ideas?
I glanced in a junkyard today and didn't see anything less rusty than what I have on there now.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-12-2008, 08:18 PM
McLeod is starting off with a positive reputation.
Hey Fredric,
Check this out:
1980-96 OEM Rear Spring Hanger
I am nothing but pleased with all the transactions I have completed with JBG.
  #3 (permalink)
Old 07-13-2008, 07:44 AM
frederic's Avatar
thank you very Much McLeod!
  #4 (permalink)
Old 07-13-2008, 07:46 AM
Lazy K is starting off with a positive reputation.
Check RockAuto as well, they should do them.
  #5 (permalink)
Old 07-13-2008, 10:06 AM
95F350XL is starting off with a positive reputation.
Seeing your in NJ. Where at I dont know. When mine rotted out I got them from Mercer Spring in Trenton NJ. It was pritty cheap also.
__________________
1995 F-350 XL 115K 5.8L 351
E4OD B&M Shift Kit
MSD 6A Blaster TIF Coil Taylor Wires
Flowtech LT’s True Dual Header Back
Flowmaster 40’s Dual 3.5” Tips Before Rear Tire
36x12.5x16.5 GY RT/II’s Military Issue
AR Baja 16.5x10 K&N 4.10 Limited Slip
1988 Bronk XLT 143K 5.0L 302
Cherry Bomb Custom Exhaust
33x12.5x15 Interico Trxus MT's
  #6 (permalink)
Old 07-13-2008, 10:29 AM
TexasGuy001's Avatar
TexasGuy001 is starting off with a positive reputation.
When you said spring perch, I thought you meant on the rear end. I got some spring hangers from NPD or LMC, I forgot which one. There is an Ebay store that has them as well. The width is really the only specification that should make a difference since there are 2.5 and 3 inch springs.
__________________
1995 F-150 XLT 2WD 5.0 AODE (4R70W) 3.55 LS
  #7 (permalink)
Old 07-16-2008, 10:46 AM
frederic's Avatar
As it turns out I found an even less costly mail order place to get them:
338-1949
$24.07 each plus shipping.
  #8 (permalink)
Old 07-16-2008, 10:58 AM
Great find.
I saved that link for future reference.
  #9 (permalink)
Old 07-16-2008, 03:35 PM
frederic's Avatar
Glad I could return the favor McLeod. For a dollar or two I'd buy from an FTE sponsor, but when the cost savings is more than half... oh well
Stenglebros also has air suspension stuff for those of us interested in adding air. While I'll be using different parts than what they offer, at least I know where to get the necessary bracketry. While I can make it, it's more work than it's worth.
  #10 (permalink)
Old 07-16-2008, 07:39 PM
The price difference might be OEM -vs- aftermarket.
JBG piece is OEM if that makes a difference.
I'm with you though on saving 1/2+ on the price.
  #11 (permalink)
Old 07-17-2008, 03:26 AM
fbama73's Avatar
fbama73 is starting off with a positive reputation.
I'm surprised you had trouble finding them- my local Stealership had them on the shelf for my truck, and at a similar price. I know it's a different part from 2wd to 4wd, but it's still an achille's heel for our trucks.
__________________
1996 Eddie Bauer F150 4X4 Standard cab, longbed
302 4R70W MAF
130K miles, headed for 250K
Go Vols!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
