Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 07-12-2008, 06:31 PM
frank13 frank13 is offline
Garage is empty, add now
frank13 is starting off with a positive reputation.
94 lightning mass air flow conversion?
I have found a donor truck with mass air flow and installed all of the duct work on top.I just need some help with the driver side oxygen sensor that also has the transmission wiring.The transmission wiring plugs are different they dont fit should i splice my old ones or look for another way?Anything will help thanks
  #2 (permalink)
Old 07-12-2008, 08:29 PM
Blurry94's Avatar
Blurry94 Blurry94 is offline
1994 Ford Lightning
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
Does the donor truck have an E4OD or a 4R70W?
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, 62lb injectors, 2800 stall converter, Eaton Locker, Pickrel Headers and Exhaust, FMS Mass Air using SCT tuning software. Road trip and dragstrip ready!
  #3 (permalink)
Old 07-12-2008, 09:09 PM
I dont know i got everything from the junk yard.How can you tell the difference in the trans?Another thing that i came across is the donor truck had the vin starting with 2F i think its from canada i cant find a EGR valve connector?
  #4 (permalink)
Old 07-13-2008, 08:40 PM
Blurry94's Avatar
1994 Ford Lightning
Comapare the transmission pans. The E4OD will be larger than a 4R70W
__________________
Matt C.
  #5 (permalink)
Old 07-14-2008, 02:02 AM
I think it is a 4R70W the pan is different.I put my original wiring from my transmission and i test drove it and it shifts normal even with out the driver side oxygen sensor.Should i just keep looking for the E40D wiring with the oxygen sensor?
  #6 (permalink)
Old 07-15-2008, 08:18 PM
Is there any way i can wire up the driver side oxygen sensor from the computer?I cant find a truck with mass air flow and E40D to put on mine any help.
  #7 (permalink)
Old 07-15-2008, 10:07 PM
Blurry94's Avatar
1994 Ford Lightning
The E4OD/EEC-4 ECU is probably not equipped to accept a second O2, even with aftermarket tuning. Get the stock O2 sensor as close to the exhaust collector as possible and it'll work fine.
__________________
Matt C.
  #8 (permalink)
Old 07-16-2008, 08:35 PM
You meen the passenger side O2?I changed the computer that came with the mass air donor.
  #9 (permalink)
Old 07-16-2008, 09:34 PM
Blurry94's Avatar
1994 Ford Lightning
If this is the same ECU that you've been running since the swap, then yes.
__________________
Matt C.
  #10 (permalink)
Old 07-20-2008, 09:39 PM
If i move the stock O2 up more,I dont need the second O2?Should that take care of my check engine light it came on after the swamp?By the way nice truck.
  #11 (permalink)
Old 07-21-2008, 01:13 PM
lostin90s lostin90s is offline
lostin90s is starting off with a positive reputation.
I had several e4od maf equipted trucks. They all have had only 1 o2 sensor .
__________________
Red Neck rule #1 If you drive a truck you should always be looking for trucks to get parts off of. If you can't find part used you aren't looking hard enough.
94 F150 XLT 4x4 SC LB MAF 302 E4od 3:55 ls rear
MSD blaster coil ,cap rotor ,Fordracing 9mm wires
  #12 (permalink)
Old 07-21-2008, 04:25 PM
Will my check engine light go away with one O2?I live in Sothern California smog is strict over here.
  #13 (permalink)
Old 08-13-2008, 05:42 PM
94 lightning mass air flow conversion problems
I did a conversion on my truck and i have a check engine light on.Bank 2 to lean.Do i need the driver side o2 sensor?Is there any way to get by that?
  #14 (permalink)
Old 08-13-2008, 08:44 PM
Heavy_Metal Heavy_Metal is offline
Heavy_Metal is gaining momentum as a positive member of FTE.
Just for reference: The ECM code for a Mass-air 351 w/ E4OD is AKCO as per the original Motorsport mass-air conversion. Don't know if that helps any.
  #15 (permalink)
Old 08-14-2008, 08:19 PM
Blurry94's Avatar
1994 Ford Lightning
The AKC0 does not use/need a second sensor, however, there are a few that do. If you have one of those then you can wire and plumb in a second O2 sensor; you'll need a print that shows where to connect the wires too.
__________________
Matt C.
Tags
94, air, akco, cam, computer, conversion, coversion, f150, flow, ford, lightning, maf, map, mass, o2, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
