10-10-2001, 09:35 AM
Compressor cycling even when A/C is off
This is how it was told to me. the air compressor pumps are designed to cycle while on the defrost setting, and here is the reasoning. In the colder months you tend not to use the ac and are more likely to use the defrost. If you live in an area with any extended periods of cold weather this cycling prevents the compressor from freezing up (mechanically not temp. i.e. corrosion, lube, ect.)where normaly you would not be using it and it would just be sittig there all winter.
