Lights
on
1 Post
The DRW lights are DOT15 sealed units, you replace the whole thing. They are only a few bucks. It may seem a bit wasteful, but these sealed units last a LOT longer than other small marker lights since water can't get inside.
Your best bet for replacements is NAPA.
The cab top lights are removable. Pull the screws and take the light off the cab. Follow the wire to the light, and you'll see a little twist off fitting at the bulb. It's a 192 IIRC.
