Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-12-2008, 12:13 AM
matt2491's Avatar
matt2491 is new and has a neutral reputation at this point.
QUICK & EASY ANSWER NEEDED - Radiator Support
As some of you guys know, the front of my truck is all messed up since at one time the PO apparently hit a pole moving at a pretty good clip.
I'm working on getting this issue straightened out (no pun intended) over this weekend. However, I just need to know something.
Whatever the PO hit got so far as to also slightly bend backward the radiator support, with a little crack formed in the metal near the middle of it. I have to get the radiator support bent back so that its straight and weld some support pieces behind it to reinforce it. Otherwise, the new grill and valence panel won't bolt on properly.
My question that I need a quick answer for is: Is the radiator support supposed to be perfectly straight from end to end all the way along the face of it, or does it bend OUTWARDS slightly towards the middle like the grill and valence panel do?
Hopefully I can get an answer to this by tomorrow morning as I'll be tackling it first thing come dawn. If someone could just go to their truck and eye down the length of the radiator support and see if its straight or bent for me, I would really appreciate it.
Thanks --Matt
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-12-2008, 12:29 AM
cobraguy is starting off with a positive reputation.
Sounds like yours is bent. The top rail should be straight from headlight to headlight.
__________________
61 Unibody preject/driver
62 Falcon 2dr
63 Ranchero
01 Saturn SC1 plastic Vega
01 Taurus Wagon, Momma's Silver Bullet
  #3 (permalink)
Old 07-12-2008, 01:06 AM
camperspecial65 is gaining momentum as a positive member of FTE.
its supposed to be flat as a pancake...or at least straight as a flat pancake would be if you were to put a straightedge on said flat pancake
- cs65
  #4 (permalink)
Old 07-12-2008, 08:40 AM
jecsd1 is starting off with a positive reputation.
Mine is straight too. Good luck
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
