Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-11-2008, 09:40 PM
tndiesel is starting off with a positive reputation.
Couple of things
I greased the front end and one of the fittings on the passenger side was loose. So I tightened it and it still won't take the grease, any suggestions?
The past two mornings the truck would not start, so I jumped it off and it started. On my stock voltage gauge it usually runs a little more than halfway but was down to about a 1/3. As I drove the truck a lot today it worked it's way back to a little more than halfway. Does this sound like a battery issue or maybe an alternator issue. There was no warning, just Thursday morning it happened and this morning.
__________________
97 F350 PSD CC dually
Tymar intake
new complete homemade battery cables
270K miles
New FLEX A LITE 32K GVWR Tranny cooler
New heater hose T made from nice Brass fittings
work in progress
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-11-2008, 10:06 PM
oldbird1965 is starting off with a positive reputation.
replace the grease fitting. most parts stores will check the output of the alternator. a quick check is to see what the voltage is on the battery not running and running. a good charged battery is 12.6 volts and with the motor running about 13 volts plus a little.
__________________
96 2WD F250 auto, 6637, guages, two trans coolers, hx, 3 1/2" DP-4", FS2500 filter, 1" turbo housing, rad filter, 6 position TW, 99 IC, syn oil, BD deep pan, Elec fuel pump, SD HPOP, 140v IDM & rear disks, Beans Tranny Savers, 203*, 'the cure', Bilsteins
  #3 (permalink)
Old 07-12-2008, 07:58 AM
Quote:
I took the grease fitting off and it looked fine but I guess any parts store carries them? Do I need to remove the alternator to have it checked?
__________________
Tymar intake
270K miles
work in progress
  #4 (permalink)
Old 07-12-2008, 08:59 AM
Yes to the testing, the belt is harder to get back on then taking the alternator off, IMHO.
__________________
  #5 (permalink)
Old 07-12-2008, 09:49 AM
So I need to get the batteries checked first?
__________________
Tymar intake
270K miles
work in progress
  #6 (permalink)
Old 07-12-2008, 05:26 PM
I would check the batteries first. I'm no expert but if you disconnect the battery cables and check the volts on each battery first to see how many volts. Then put the cables back on and start it up and while its running check the volts on each battery. If its more volts running, then the alternator is at least putting out something. If it still acts up then take the alt off and get it checked.
__________________
  #7 (permalink)
Old 07-12-2008, 05:53 PM
One battery was almost completely dead and drawing from the other one so I got two new ones. I was in a pinch and a hurry and the only/best thing I could find was two Bosch brand batteries with 1000 CA and 850 CCA. Three year free replacement warranty. Cranked right up real strong with the new batteries.
__________________
Tymar intake
270K miles
work in progress
  #8 (permalink)
Old 07-12-2008, 08:03 PM
Its a good thing you replaced both battery's. I don't know about Bosch barreries but you made them sound good. I just replaced my eight year old interstate batteries with a new set, like you said, cranked right up.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
