Help! Sirius does not display info - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 07-11-2008, 07:03 PM
wahooman wahooman is offline
wahooman is starting off with a positive reputation.
My wife has a 2007 Expedition with the factory Nav and Rear DVD. The dealer is trying to add Sirius radio to the factory radio and it isn't working. I can hear the music/talk from the Sirius channels but the head unit does not display the channel,artist, or song information. The dealer has replaced just about every component in the system and the system will still only display info for a couple of times and then the info display goes blank, never to return.
Any ideas out there?
Wahoo
Old 07-12-2008, 11:22 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
What exactly has the dealer replaced?
Old 07-12-2008, 05:49 PM
From what I understand, the dealer has replaced the two Sirius components(?) and the head unit in the dash. The truck goes back in this week to replace the power relay. The radio will display song infomation when first installed but after several power on then off cycles, it quits displaying infomation. At that point you can still hear Sirius music, you just can't tell what channel you're on or artist/song information. I know last summer when I called another dealer, he said that you could not have Sirius installed if you had the Nav/Rear DVD package in a 2007 Expedition. He said Ford was working on a fix for this and should have one by spring 2008.
Old 07-12-2008, 07:38 PM
TIKT B8 TIKT B8 is offline
TIKT B8 is starting off with a positive reputation.
Did they mean that it cannot be installed after the fact or that it is not compatible with the Nav/DVD? I am assuming that you mean installed after the fact because I have nav/dvd and sirius.
Old 07-13-2008, 06:08 AM
They (Ford) originally said that you couldn’t have Sirius dealer installed (not factory) because it was incompatable with the Nav/DVD in a 2007 Expedition. I just can’t figure out why it works until you turn the truck off and power it back up.
TIKT B8, do you have the interface that allows you to use the factory radio controls?
Old 07-13-2008, 04:47 PM
Mine is all stock. I did install the navigation unit after i bought the car, but i did install an OEM nav unit. But, yes I do have steering wheel controls.
Old 07-18-2008, 02:25 PM
Dealer installed a power relay part to the system this week and all appears to work okay. Thanks for the responses. I'll let you guys know if it stops working again.
Old 07-28-2008, 02:04 AM
nckracer's Avatar
nckracer nckracer is offline
nckracer is starting off with a positive reputation.
Quote:
Originally Posted by wahooman View Post
They (Ford) originally said that you couldnít have Sirius dealer installed (not factory) because it was incompatable with the Nav/DVD in a 2007 Expedition. I just canít figure out why it works until you turn the truck off and power it back up.
I had my dealer install Sirius to my '07 with navigation and I've never had a problem with it. Your (Ford) source is wrong. My VIN is *A000168* one of the first ones built in July of '06, so I'm sure it will work on anything built after that.
Sirius Satellite Radio for the garage - any rec's? Fat Diesel General NON-Automotive Conversation 0 02-29-2012 09:29 PM
2011 Factory Radio with Sync edjunior 1999 to 2016 Super Duty 2 11-29-2011 09:56 AM
Sirius Install activation problem bdb2047 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 11 12-01-2008 06:20 PM
Satelite Radio Help needed Vikefanman Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 5 10-29-2008 10:27 PM
scroll radio display InboundFX4 2004 - 2008 F150 1 10-27-2006 11:19 PM
Tags
display, dvd, f150, sirius
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
