Quote:
Originally Posted by Ole'Blu
This may sound like a stupid question, but do I need to remove the bearings from the hub to replace my old rotors on my 1995 F150???? Any help is appreciated!!!
Ole' Blu
First off, there are never stupid questions. We are all here to help each other!
If you are replacing your old rotors with new ones, and I'm assuming it is not a 4x4, I would replace the 4 bearings and 2 seals. You can use your old bearings, but bearings are less than $10 each and seals are even cheaper. All rotors I have replaced already have the studs and inner bearing races pressed into the hub, so no need to press. Just make sure you pack those bearings good. Put on a pair of rubber gloves and get messy!
BTW, Thank You for your service!
