Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-11-2008, 02:09 PM
Chad Winship is starting off with a positive reputation.
Error code 122
"Throttle Position Sensor below minimum voltage"
could this send a truck into a sort of "limp mode"" where the transmission would shift badly? trnsmission was shifting really hard, all gears
Waiting to hear back form the shop if there where any other codes with it.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-11-2008, 04:21 PM
Kemicalburns's Avatar
Kemicalburns is gaining momentum as a positive member of FTE.Kemicalburns is gaining momentum as a positive member of FTE.
need info. what year/engine/tranny are we talking about there. and why would you have it at the shop and then ask us questions. should be the other way around, let us help you then go to a shop if we cant :-)
__________________
94 XLT 5.8/E4OD
6"ProComp Stage II 35x12.5x15 BFG MT's ,
4.88 gears f/r
installing soon: JBA shorty, Bassani Y pipe, Edelbrock efi truck intake, , aussie front/rear
88 (Rolled)
http://www.supermotors.org/registry/vehicles/detail.php?id=4158
  #3 (permalink)
Old 07-11-2008, 04:34 PM
Hey, sorry , You make a fair point...
it's a 93 XLT with the 351 and the e4od trans.
Posted a thread a couple months back, tranny was shifting REALLY hard, all gears.. otherwise running good
bought the scanner you guys reccomended and couldn't get any codes. tried shorting the ground on the scanner like it recommended, tried contact cleaner, no codes...
So I was stumped and too it to the transmission shop. they couldn't pull codes either. $75 in labor they found a busted wire in the test harness, pulled the code 122
saying that's a throttle position sensor, so they're nopt recommending internal trans service, $350 for the electronic diagnostics/repair, new TPS, plus a trans flush/filter/gasket. I dunno.... hate paying others to do this simple stuff but my weekends are shot I just didn't have time or energy to try and monkey myself...
But before I tell him to go ahead, is it reasonable that bad data from a TPS could be causing the computer to send bad shift info to the trans?
  #4 (permalink)
Old 07-11-2008, 06:09 PM
your bronco gets shift signals from various sensors. tps is possible but should and can be replaced by you for cheap and is located under the throttlebody taking 15-30mins max, i would not have a tranny shop touch a sensor on the engine as thats not what they specialize. another sensor that might be the issue is the MLP solenoid pack or even the sensor that sits on top of the rear pumpkin (also known as the VSS)
is your speedometer working properly? is your ABS light on at all?
__________________
94 XLT 5.8/E4OD
4.88 gears f/r
88 (Rolled)
  #5 (permalink)
Old 07-12-2008, 07:41 AM
Speedo words fine. No ABS light. Truck runs fine, idles normal.
And the shifting issue cam on suddenly... I don't have my haynes with me right now but are those other two sensors equally easy to replace? Only code was that 122, throttle position, so I don't suspect the others but who knows.
Also, I have a leak in the rear main, small one. For the 20-30 miles a week I drive this truck I can just keep putting an extra quart a month in it but if I did decide to do a repair (have it done) any idea ballpark what kind of cost I'm looking at?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
