351C 4V Spark-plug wire question - Ford Truck Enthusiasts Forums
Old 07-11-2008, 02:50 PM
abelmoreno abelmoreno is offline
abelmoreno is starting off with a positive reputation.
Hello guys,
Would you please tell me thew spark plug gap I should set my plugs to?
I've got a 1973 351C 4V with an HEI distributor (coil on cap - chevy style) Taylor 8mm Hi-Energy cables & Autolite AP25 plugs.
Thanks
Old 07-12-2008, 10:46 PM
grclark351 grclark351 is offline
grclark351 is gaining momentum as a positive member of FTE.
i'd go .040"
Old 07-13-2008, 04:01 AM
hollenjoe's Avatar
hollenjoe hollenjoe is offline
hollenjoe is starting off with a positive reputation.
every ford engine ive checked on nappas store on s plugs gaps says 0.040"....
Old 07-14-2008, 10:14 PM
Thanks a lot.
Won't the HEI dizzy make a difference? Or 0.40 is what you recommend considering the dizzy already?
Old 07-14-2008, 10:23 PM
it's a dependable gap, a little more than the common .035" for points, and with the HEI it should never miss a beat. of course you can always try .045" but make sure your plug is capable of that gap without bending the electrode at an angle to get it. there are different plugs specifically for wider gaps, the electrodes are longer and don't need to be mis-shaped.
extended tip plugs are usually designed for the wider HEI gaps.
Spark Plug Gap for 361 with 4v ?? 1975-F6004x4Dump Large Truck 2 02-12-2014 07:00 PM
copper v platinum v iridium plugs 351Cleveland C4 Performance & General Engine Building 14 07-15-2013 02:38 PM
Spark plug gap?? March bracket on a 351M?? crakerjack51 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 1 02-23-2008 05:33 PM
4.0 Engine Spark Plugs? sjrogers Ranger & B-Series 10 03-02-2007 12:44 PM
NGK - V Power Spark Plugs - Any Good? lt 1987 - 1996 F150 & Larger F-Series Trucks 5 06-30-2002 09:37 PM
Tags
1970, 351, 351c, 4v, ford, gap, hei, motor, mustang, placement, plug, plugs, point, race, spark, sparkplugs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
