Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-11-2008, 02:30 PM
gcastle is starting off with a positive reputation.
I Need help..Front End Bouncing/Hoping
Hmm,
Okay so I bought a 93 4x4 F150 XLT about 1-2 months ago. it has about 152K miles on the body and only about 8500 on the factory installed 302 motor and has been serviced about every 3000 miles(is due again). so even though it is 15 years old it still runs like new. It has a.. 4 in. suspension SkyJacker lift, 33in BFG tires(about 800 miles in), Ion wheels, Air Lift airbags on the rear, and so on.
The problem im having is that when ever i have to make a slight left hand curve, it feels like im in 4 Wheel drive with the hubs locked driving on cement. the cab will bounce and hop to the point where i will have to straighten out a little bit as i go around the corner or slow down to about 15-20. Im pretty sure(not 100%) that its only the front drivers side that is the problem. its quite scary going up hill wich is about 75% of the time this happens.
I took it in to the Ford dealership(didnt solve anything). They replaced the right front ball joints and the front brake pads, resurfaced rotors and rear drums, packed the 4x4 hubs and bearings, and replaced the brake master cylinder, then flushed the brake system. $700
So after all that, anyone have any ideas why this is happening?
Thanks,
Galen
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-11-2008, 02:55 PM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
Can you confirm both front hubs unlock and the drive axles and driveshaft do not turn when the vehicle is in 2wd.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, Roller Rockers, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, sliding rear window.
  #3 (permalink)
Old 07-11-2008, 03:11 PM
danr1 is gaining momentum as a positive member of FTE.
You state they fixed and lubed the front end and installed new ball joints, was the u-joint just behind the front wheel found to in good shape?
And are both of them in good shape?
The center joint could be froze up some but would not be likely to create the issues you describe. One or both of the outer u-joints may though.
Having the ball joints out for replacement they would have had the axle out to do it, they should have replaced it at that time. u-joints are cheap, labor/time spent to get to them is not, especially them u-joints.
Right front apart? Center joint should have been done right along with the outer joint on a 15+ year old truck if it is still the "stock part" in there, could very well be at that.
The center joint can be replaced working under the truck while the outer shaft assy is already out.
__________________
87, 94, 95 F250
89 Bronco II
96 Explorer
  #4 (permalink)
Old 07-12-2008, 09:27 AM
lostin90s is starting off with a positive reputation.
A bad u jiont will do that . And never take to Ford dealer . (u found out why $$$) They replace not fix . If they take it off a new part goes on.
But See if they did u-joints for that price they should have .
__________________
Red Neck rule #1 If you drive a truck you should always be looking for trucks to get parts off of. If you can't find part used you aren't looking hard enough.
94 F150 XLT 4x4 SC LB MAF 302 E4od 3:55 ls rear
MSD blaster coil ,cap rotor ,Fordracing 9mm wires
  #5 (permalink)
Old 07-12-2008, 06:22 PM
lv2race's Avatar
lv2race is starting off with a positive reputation.
Disconnect/remove the front drive shaft and try it. Maybe bad u-joints in the D/S.
__________________
J Lowe
'90 F-150, 4.9
'00 Expo, Triton 5.4
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
