Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-11-2008, 02:21 PM
chas31310 is starting off with a positive reputation.
Tranmission gauge for 99 ford 4x4 powerstoke
I've a recent problem with the tranny fluid getting hot and puking out a qt or so when towing at higher elevations and typical 100 degree summer days. I've installed an additional cooler and replaced fluid with synthetic. Before I invest in other products I believe installing a tranny gauge is best. Do any of you know if the transmission has a port, or plugged hole for installing a gauge or will I need to have a shop perform the work and tap in a hole for the new gauge. I have the Lariat modle. I would assume if the tranny has the port I can install the sensor without draining any fluid. You help is always appreciated. Thanks, CJ
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-11-2008, 05:34 PM
ReAX's Avatar
Molon Labe
ReAX is gaining momentum as a positive member of FTE.ReAX is gaining momentum as a positive member of FTE.
Yes there is a pressure port on the pass side just above the cooler lines.
How about this Gauge Install PS 99 Pyro, Boost & Tranny
__________________
Too many mods to list, so click here.
-MECP 06/27/08
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
there's a very fine line between not listening, and not caring. I like to think that I walk that line every day of my life.
  #3 (permalink)
Old 07-11-2008, 06:17 PM
ron's power stroke's Avatar
FORD the rock crusher
ron's power stroke is a splendid one to beholdron's power stroke is a splendid one to beholdron's power stroke is a splendid one to beholdron's power stroke is a splendid one to beholdron's power stroke is a splendid one to beholdron's power stroke is a splendid one to behold
on the driver side of the trans..just above the lip of the pan.. you will see a plug..have sensor ready..pull plug and stick sensor right in..you may get wet from the oil...drop down to the 99-03 7.3 forum..lots of good info down there for most any thing you need...also that mods and fixes link in my sig is pretty handy to have...
__________________
Early 99 7.3 F350 auto,AFE stage2 5" strait pipe. DP tuner ,140 IDM,Modified 17* HPOP..DI RR
Ryan Casserly's SS stage 2's moded 100% over nozzles
exploded view of a 7,3
Reconstructed 7point3.com
  #4 (permalink)
Old 07-12-2008, 12:44 PM
superduty4x4's Avatar
superduty4x4 has a great reputation on FTE.superduty4x4 has a great reputation on FTE.superduty4x4 has a great reputation on FTE.superduty4x4 has a great reputation on FTE.
Don't forget some RTV or Teflon tape for the threads on the sender before you put it in. I installed mine dry and it's dripping so you'll definitely want to use some type of sealant.
__________________
Chase
1999 F250 XLT C/C Shorty 4x4 PSD
2000 Explorer XLT 4x4 (wife's)
1992 Tempo GL- deer basher. Score: Tempo-2, Deer-0
PAA Member #2!
ThumperTalk
All Things Moto!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
