Brush Guard/Plow Frame
Ok folks, I have a question for everyone. I've been looking for a brush guard to put on my '06 F250SD CC FX4. The problem being, I plow with it in the winter time. I've done a bit of searching, and have yet to find a brush guard designed to "clip" on via an existing plow frame. Now, keep in mind, this is a new Boss 'V' plow, not the old style with the entire lift arm, cylinder and everything mounted on the truck....just the sub-frame under the bumper. Has anybody seen something like this? Any idea if anyone out there makes one?
I'm just looking for an easier way to be able to mount/dis-mount the brush guard each season....seems like something someone would have thought of by now....
Thanks in advance for your thoughts/answers!
Most of the brush guards use the 4 bolts that hold the stock bumper on. You remove the top 2 I think and loosen the bottom to and slide it over them. Then re-install the top ones. It only takes a few minutes if you have a couple of buddies to help. I would think you could do that every spring/fall if you really want one.
I agree it would be nice to be able to hook it to the plow frame and pull a couple of pins to remove/install it.I have to unbolt mine to put my plow on.Its too much work to do every time it snows so I have to leave it off all winter.It bolts on the four bumper bolts.It would be nice if there was a brush guard that you wouldn't have to remove when the plow is on.
Sounds like you've got a good idea there. You should make up a prototype and see how it works. Who knows, you might end up making some money off of it
I have a westen brush gaurd and a western pro plow and the brush gaurd stays on all year long.its an ultra mount plow so it goes on with two levers and two plugs and the brush gaurd stays on the truck, it does attach like beerstalker says so if I had one of those big a$$ V blades 4 bolts and the gaurd comes off.
Find the brush guard you want, then surf to www.jerres.com. Contact him, he will be able to make it work, and a pilgrimmage to Erie might be a useful thing. Tell him I sent you. He is probably the most knowlegable guy in the snow plow business.
Have you tried a guard to see if it will work with the new plow style? You might get lucky and it have it fit with a stock guard just fine. On the other had, it can't be that hard to make one that would fit onto your mounting setup. You might just have to get a normal one, then take it to a fab shop where they can make/modify the center section.
I've been looking at a number of different styles for the last couple of weeks, just haven't made a final decision yet. I was looking at a Westin until our new light rescue came in at the Fire Department. Not sure if its the brush guard itsself, or if it's the '08 F350....but let me tell you, the brush guard sits AT LEAST 9"-10" in front of the grille/head lights. I'm not too keen on that my self. I'm going to try and take a closer look at it here in the next couple of days, but i'm not too sure what the deal is.
I am definitely considering doing a little "fab" work myself to make this work, just not too sure if i trust my welding work! Being that i learned to weld on the farm with a stick only....my welds are usually functional, not necessarily pretty!
My brother, a welder, copied his diconnected part of his plow frame and welded up a couple different mounts that slide right into his fisher plow frame that is always connected to his truck. one of the mounts is for his 10000lb winch and the other is for a brush guard that he retro fitted to the mount. Both work real well and look pretty good as well. I will try to get pics for you.
