Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1999 - 2003 7.3L Power Stroke Diesel Sponsored By:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-11-2008, 11:39 AM
HKusp's Avatar
Hates Liberal Pansies
HKusp has a very good reputation on FTE.HKusp has a very good reputation on FTE.HKusp has a very good reputation on FTE.HKusp has a very good reputation on FTE.
Can we run #1 diesel in our trucks?
I was cruising craigslist and a guy has about 300 gallons and he is selling it for 1000 bucks. $3.33 a gallon sounds really good to me. I am unsure if it has die in it or not. If it does, I will leave it alone but if we can run it, I would be interested. I thought that in the Northern climates they run #1 in the winter so I thought it was feasible.
__________________
-Jason PAA Member #3 (with some booosht!)
2003 F250 CC SB Lariat 4X4
- DP Tuner NS, Stock, High Idle , 60Decel, 60tow, 80"E", 120R ,140AGG, Lope Idle
Isspro 3 gauge set, 6637 Filter, Zoodad, Overboost Annihilator, straight pipe muffler delete, Fumoto, Napa Ultra-cool auxiliary transmission cooler.
http://www.7point3.com/
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-11-2008, 11:42 AM
mndiesel is starting off with a positive reputation.
Running #1 diesel is ok but one question I would have is how long has it been sitting in the tank. Condensation could be a problem!!!!
__________________
Tom
99.5 f-250 sd ec, 4x4, auto, dp-tuner 40t/60t/80e, DiPricol guages, bts vb, itp reg return, intank/prepump, hdx crossover, ford AIS intake, ats turbo shroud, 4" SS Magnaflow exhaust, overboost elim, ccv mod, tru-cool 4739 max, schaeffer 9000. Auto enginuity, roadside help network.
  #3 (permalink)
Old 07-11-2008, 11:51 AM
parkland's Avatar
parkland is gaining momentum as a positive member of FTE.
Yeah, theres oil rig guys selling diesel, for dirt cheap, but who wants fuel thats been sitting around for months in an old steel tank?
__________________
2002 7.3 PSD 4x4 Nothing out of the ordinary.
  #4 (permalink)
Old 07-11-2008, 12:21 PM
HKusp's Avatar
Well my neighbor and I built a complete trailer mounted rig for converting used vegtable oil complete with an electric fuel pump. I think that we can safely filter and remove any condensation and/or debris if we decide to get this supply. I just want to know if it will hurt anything if I do it.
__________________
  #5 (permalink)
Old 07-11-2008, 12:24 PM
F350-6's Avatar
Slow Typing
F350-6 is a name known to allF350-6 is a name known to allF350-6 is a name known to allF350-6 is a name known to allF350-6 is a name known to allF350-6 is a name known to all
I thought they mixed #1 & #2 up there in the winter time for your winter fuel? Number 1 will have a lower BTU content which means lower MPG's, and also needs more lubricity added to it. The big question is, how old is the fuel? Diesel can go bad just like gas.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 260,000 & counting. 6637 w/ Pete's armor. Cold air set up for 6637
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
MORE (Military Online RElay)
  #6 (permalink)
Old 07-11-2008, 12:28 PM
HKusp's Avatar
I will look into it and see what I find out. I will let you know what comes of it. I buy fuel power service by the case and I quart treats 250 gallons so the lubricity issue shouldn't be a problem.
__________________
  #7 (permalink)
Old 07-11-2008, 12:53 PM
ron's power stroke's Avatar
FORD the rock crusher
ron's power stroke has a great reputation on FTE.ron's power stroke has a great reputation on FTE.ron's power stroke has a great reputation on FTE.ron's power stroke has a great reputation on FTE.ron's power stroke has a great reputation on FTE.ron's power stroke has a great reputation on FTE.
i would filter it out good before i put it in my truck..this goes from one place to the next in bolk and un filtered..in other words you dont have a gas pump that cleans the crud out before it goes into your tank...also mixing it with on road as you burn it is a good idea....you can also expect lower MPG..
__________________
Early 99 7.3 F350 4x4, auto, 99.5 turbo with WW,AFE stage2 5" strait pipe DP Tuner ,17* HPOP sent out to be modified
www.7point3.com
exploded view of a 7,3
mod's & fixes
  #8 (permalink)
Old 07-11-2008, 01:12 PM
HKusp's Avatar
I have a trailer with several 55 gallon drums with gradually smaller and smaller micron filters with water separators on it too. The pump is hooked up to the last holding drum for the finished WVO.
__________________
  #9 (permalink)
Old 07-11-2008, 01:14 PM
Smokin''s Avatar
Smokin' has a very good reputation on FTE.Smokin' has a very good reputation on FTE.Smokin' has a very good reputation on FTE.Smokin' has a very good reputation on FTE.
I'm with the guys, I'd take a close look (or close smell) at that stuff and make sure it isn't rotten. Sounds a little fishy to me.
__________________
Lisa
Early '99 long bed XLT supercab. 4" Pro Comp suspension lift, 35" BFG AT's, Hypermax Boost Pyrometer, 4" turbo back exhaust setup, Hypermax 330 chip.
  #10 (permalink)
Old 07-11-2008, 01:15 PM
HKusp's Avatar
I am going to go see if I can take a look. I will let you know what comes of it. Thanks for the input guys/gal.
__________________
  #11 (permalink)
Old 07-11-2008, 01:17 PM
Quote:
i hope i dont see you and your truck/trailer on TV...parked over a filler cap sucking fuel out the ground...lol might also check and see if the fuel is dyed...most heating oil is....
__________________
www.7point3.com
mod's & fixes
  #12 (permalink)
Old 07-11-2008, 01:22 PM
HKusp's Avatar
Diesel Fuel #1 300 Gal.
Here is the ad, I am waiting on a call back from the guy.
__________________
  #13 (permalink)
Old 07-11-2008, 01:27 PM
JEV JEV is offline
JEV is starting off with a positive reputation.
#1 will burn fine. We burn #1 here all winter. You see the #1/#2 blends in the late fall and then when winter really starts rolling it's all #1.
I would also check on how old it is. If you could pump it through a fuel/water separator all the better....
JEV
__________________
2001 F-350 7.3L CC LB XLT 4X4
Stock exhaust straight piped, HPX, 6637 intake, CCV Mod, In tank prepump mods, Boost Pyro Tran Gauges, Overboost Reg., DP Tuner 60Tow, 80Econo, 120Race
  #14 (permalink)
Old 07-11-2008, 05:42 PM
totin_tools is starting off with a positive reputation.
Isnt #1 fuel basically Kerosene? When I drove thru Montana they had #1 and #2 at the pump IIRC the #1 was cheaper by about $0.25 or so. When I sent the wife in to pay and ask the lady told her make sure he doesnt use the #1 or else he will be getting worse mileage and other things.
__________________
Jamin
2000 PSD dually crew cab 4x4 AKA "Redneck Cadillac" with BTS trans, 6.0 trans cooler, Cales 6 position custom chip, 55 gallon toolbox fuel tank combo, CB radio, HPX, 4" stainless exhaust, Sirius radio, 05 Harley Davidson headlights, AFE 6637
  #15 (permalink)
Old 07-11-2008, 06:30 PM
Markadeck's Avatar
HATES ANY TERRORIST----->
Markadeck has a very good reputation on FTE.Markadeck has a very good reputation on FTE.Markadeck has a very good reputation on FTE.Markadeck has a very good reputation on FTE.
I have used really old fuel, and I mean really old in my motor home over the years with no ill effects. But, maybe I was just lucky. I did nothing with it but pump it out of several old 18 wheeler tractors and haul over to my motor home and pumped it in. That was years ago and the motor home (Cat 3208) still runs perfect.
__________________
Mark
Above car featured in Sept. '83 Super
Stock & Drag Illustrated. No longer mine.
1999.5 F-250 2x4 Extended Cab Long Bed
209,351+miles
custom leather interior
6637 Mod
4 inch SS Straight Pipe
DP Oh Boy! Need I say more?
PhD In Common Sense & Logicalogy
University of Hard Knocks
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
