Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Expedition & Navigator 1997 - 2002 and 2003 - 2006 models
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-11-2008, 12:03 PM
indebt's Avatar
indebt has a good reputation on FTE.indebt has a good reputation on FTE.
2000 expedition p0500
I am trying to help a neighbor with his expy. He says it hesitates sometimes and only when its warmed up, of course when he came over it was running fine. I hooked up my AE scanner and it shows p0500. its a 2000 expidition 2wd xlt. Is it as simple as replacing the speed sensor (on the rear diff?).
thanks guys.
__________________
JORGE
http://guzzle.rbmicro.com/7pt3/Mods.html
MODS : 4" EXHAUST, EBPV DELETE, 1.0 EXHAUST HOUSING
ATS , CCV, ZOODAD , 6637, IN TANK MODS, HPX, GAUGES 6.0IC, TRU-COOL, DP TUNER
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-11-2008, 02:10 PM
04markIII's Avatar
04markIII is starting off with a positive reputation.
abs light on as well?
__________________
SUPERCHARGED 2003 Expedition Eddie Bauer: 03 harley supercharger, 6lb lower pulley, k&n panel filter, magnaflow catback exhaust. 339 RWHP, 440 RWTQ. lund window visors and bugshield, black headlights, eclipse 5510 head unit, autometer c2 cobalt boost gauge, white face gauges, f150 20" oem rims
  #3 (permalink)
Old 07-11-2008, 11:58 PM
indebt's Avatar
actually no, no ses lights at all.....
__________________
JORGE
  #4 (permalink)
Old 07-12-2008, 04:20 PM
pdqford is starting off with a positive reputation.
Quote:
So, is this P0500 a pending code only?
The P0500 is saying that the PCM detected a problem in the vehicle speed information. The problem is that the PCM gets its vehicle speed info from the VSS, the TCSS (4WD only), the ABS module, the GEM module, or the CTM (Central Timer Module). Additionally, if the engine rpm is above the torque converter stall speed and the engine load is high, the PCM will infer the vehicle must be moving and set the P0500 if it doesn't receive any vehilce speed info.
My guess is that the P0500 is an intermitant and sperate issue from the hesitation complaint.
__________________
Jim in Central NY
'79 2WD F-150 Lariet w/302,4spd OD, 228,965 mi. (Original Owner!)
'02 4X4 Navigator (Newbie)
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
