Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-10-2008, 10:47 PM
gordeaux is starting off with a positive reputation.
"02 Brake lights
Help,
I just had my truck inspected and it passed, but right down the road from the dealership, a nice lady came up and told me I had no brake lights. Except the third light on the cab. I've checked the fuses and the connection and the bulbs, everything looks good! Any help out there?!!
Thanks
Gordeaux
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-11-2008, 10:28 AM
DieselCamper01's Avatar
I am finally a...
DieselCamper01 is gaining momentum as a positive member of FTE.
Did you check both fuse blocks? This is more of a bump than any help.
__________________
Jay
2001 F350 Lariat CC LB 4X4, MagHytech trans & rear cover, 6637, CCV, in-tank mod & filter, DiPricol pyro, trans, boost, EBPV delete, foil delete, Cryo Powerslots/front, Hawk pads, LED mod, Bilsteins, IDM mod, Fumoto
  #3 (permalink)
Old 07-11-2008, 01:28 PM
aldridgec's Avatar
aldridgec is gaining momentum as a positive member of FTE.
The turn signal switch could have issues, since them ain brake lights are also the turn signals. The 3rd light comes straight off the brake switch. Try playing with the hazard switch, as they can get sticky contacts inside the tss, sometimes that will free it up. You may be able to remove the switch and clean inside if you are handy, but I don't think they are that expensive.
__________________
Chris
ASE Certified Master Automotive Technician
Current Vehicles:
2002 F-250 7.3L PSD 4x4 XLT
2002 Sunset Orange Mettalic WS6 Trans Am Convertible
"Maybe is for those who lack skill"
  #4 (permalink)
Old 07-11-2008, 02:33 PM
I finally broke down and brought it to the dealer. I had to have the blinker arm and relay replaced. It had shorted out/broke. I would have never found it myself. Around $300 to repair, but what are ya gonna do?!
Thanks anyway guys
Gordeaux
  #5 (permalink)
Old 07-11-2008, 04:52 PM
Beerstalker's Avatar
Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.
Actually that is a fairly common problem and we would have diagnosed it eventually. You probably could have fixed it yourself for under $100.
Glad you got it fixed though.
__________________
2007 F350 Lariat, CC, LB, 4x4
4.5" DR Lift w/35x12.5r20 Toyo Open Country M/Ts
Keystone Restyling Ram Air Hood W/Airaid Intake & Pre-filter
Recon Smoked Cab, Mirror, and Brake Lights
MSD Dashhawk w/A Pillar Mount
Dieselsite Coolant Filter
Lund Eclipse Window Vents
Weatherguard Toolbox
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
