Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-10-2008, 10:00 PM
grass happens is starting off with a positive reputation.
99 non-SD f250
I'm looking at a 99 NON-Superduty f250 4x4. However, I am finding it very difficult to get any information on them, as it all pertains to the SD 250. I am aware of most of the differences, but do have some questions.
1. do these trucks have any major issues/common problems?
2. I'm assuming the front end is rather similar to the 150 component/design wise, did these have any problems other then the inherent weaknesses in all IFS designs.
3. it has a plow, and I would plow with this (an 8ft Meyers e-60). besides not being as strong as the solid front axle, what are the cons of this? my friends all run SDs or dodges and say they would never plow with an IFS truck. However, there does seem to be more then a few chevy owners out there that seem to push snow just fine.
I'm waiting to get the mileage, but it is a clean regular cab long bed. He is asking 5000 with plow.
Thank You all
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-10-2008, 10:04 PM
redford's Avatar
redford has a good reputation on FTE.redford has a good reputation on FTE.redford has a good reputation on FTE.
Is that the truck with the odd 7 bolt rims?
__________________
ANG Msgt (ret)
2007 F-250 Super Cab Short Bed 4x4 XLT Sport Package
5.4L 3.73 LS Tow Command and a
Flamed Dashboard Devil Duck
Presently working as a military contractor in Afghanistan.
  #3 (permalink)
Old 07-10-2008, 10:14 PM
hmm, i don't know. were all 99 non-sd f250's so equipped? thats kinda goofy. I never thought to count the lug nuts...
also what is the correct nomenclature for this? Non-Superduty? Light duty?
  #4 (permalink)
Old 07-11-2008, 12:12 AM
2002 F350V10 is starting off with a positive reputation.
I think it is called an F250 7700
  #5 (permalink)
Old 07-11-2008, 12:45 AM
Beerstalker's Avatar
Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.
The 99 F250 he is talking about is pretty much the same thing as the 99 F150. It has a little beefier suspension and axles (alnog with the strange 7 bolt rims). In 2000 Ford decided to call it the F150 with heavy service suspension or something like that. Too much confusuon between it and the F250 Super Duty.
He should ask his questions in the 97-03 F150 forum. It actually mentions the 97-99 F250 Light Duty in smaller pring underneath the main forum name.
1997 - 2003 F150 - Ford Truck Enthusiasts Forums
__________________
2007 F350 Lariat, CC, LB, 4x4
4.5" DR Lift w/35x12.5r20 Toyo Open Country M/Ts
Keystone Restyling Ram Air Hood W/Airaid Intake & Pre-filter
Recon Smoked Cab, Mirror, and Brake Lights
MSD Dashhawk w/A Pillar Mount
Dieselsite Coolant Filter
Lund Eclipse Window Vents
Weatherguard Toolbox
  #6 (permalink)
Old 07-11-2008, 08:32 AM
thank you!
  #7 (permalink)
Old 07-11-2008, 10:32 AM
4wheelfurry's Avatar
4wheelfurry is starting off with a positive reputation.
Quote:
They only referred to it as a 7700 after 99 when they droped the 250 plate. Then it became a 150 7700.
Very confusing!!
But yes they were all 7 lug for what ever reason
__________________
Early'99 V10 SC SB XLT 4X4 / 7" lift / Factory '08 Lariat 20s / '07 front end swap / '08 rear Lariat bumper / H.D. paint scheme
Soon to come: / HD Leather / wood grain / 4.56s / 37s
  #8 (permalink)
Old 07-11-2008, 01:23 PM
aldridgec's Avatar
aldridgec is gaining momentum as a positive member of FTE.
The f250 LD in 97-99 had many variations. In general the frames, torsion bars, rear springs, rear axle and wheels were heavier across the entire model. However, engines, tires, transmissions and other options were not consistent.
When the F250 LD was dropped for the 2000 model year, and the 7 wheel lug truck became an option package called the F-150 7700, options were more consistent and limited. All trucks came with a "heavy duty" automatic, although it is still debated if it was always a 4r100, 5.4L engine, 10.25 semi floating rear axle, heavy rear springs (with a very high rear payload, mine had 2900lb bed capacity), upgraded cooling, upgraded spindle bearings, torsion bars, frame section, brakes of course were different same as a lightning.
My guess on the wheels is that they didn't want someone to try and put the superduty wheels on there if they used 8 lugs. Guess they could have made the bolt pattern different somehow...
__________________
Chris
ASE Certified Master Automotive Technician
Current Vehicles:
2002 F-250 7.3L PSD 4x4 XLT
2002 Sunset Orange Mettalic WS6 Trans Am Convertible
"Maybe is for those who lack skill"
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
