Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-10-2008, 09:58 PM
73cntry is starting off with a positive reputation.
Automatic Trans VS Manual
Actually It's more a two part question I'm looking at a 03 F3504x4 Crew cab dually with a 4spd automatic, and was wondering if a 5spd automatic is better or not, and how long do automatic trans last compared to manual. My other truck I had was a 5 spd manual which was Awesome but had to sell it at the time.
__________________
04 F150 Heritage 4.2
98 Jeep Wrangler
04 Chrysler Pacifica
94 F250 7.3 DI Turbo Diesel 5spd
4x4 ext cab 8ft bed No Mods yet
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-10-2008, 10:06 PM
deereman4020's Avatar
deereman4020 has a good reputation on FTE.deereman4020 has a good reputation on FTE.
with atuo trannys you loose up to 25% of the engines power and dont last long if you start modifying the truck id go with a manual tranny besides you dont have to modify the tranny to hold up to the power but if i had to go with an auto id go 5 spd more fuel ecomomy at crusing speed
__________________
2002 Ford F-250 7.3 psd crew cab long box
6637 waiting to go in.
PAA Member #63
Support the troops
Jacob
  #3 (permalink)
Old 07-10-2008, 10:07 PM
papadelogan's Avatar
Smoke 'em if ya got 'em
papadelogan has a good reputation on FTE.papadelogan has a good reputation on FTE.
5spd auto (5R100) only came with the 6.0 motor or newer so if it's a 4-speed auto (4R100) you've got a 7.3 underhood. We're biased here, but the 7.3 is definitely the slower, but more reliable, serious workhorse engine. The 4R100 is certainly the weak link in the drivetrain, but mine's at 139,000miles and still going good. WHEATINA is a wheat farmer and told of once needed to pulled a dead harvesting truck up a slight grade for 1/4 mile with his 99 dually auto - that harvesting truck weighed 49,000lbs so it's not THAT weak (unless you plan on racing it). I don't tow super-heavy or very often but if you are easy on it, change fluids regularly, and watch your gauges you can make them last. Once your tranny does go, you can get a BTS or John Wood tranny and be pretty much bullet-proof.
The manual tranny is the same (though gearing *might* have changed slightly over time - not sure) and is the ZF-6 whether it's a 7.3, 6.0, or 6.4. You'll get better mileage with the manual, just be busier while driving is all. If you loved the 5-speed manual then look for a manual. All about personal preference basically, but 6-speeds are pretty rare.
__________________
Brendan
1999 F250 CC SB 4x4 7.3 PSD named "Nyx"
BTS VB;DP chip;6637;A-pillar (pyro, boost, trans temp);XM radio;Alpine CDA-9831 w/RCA inputs;Leveling kit;SS HPX;coolant filter;airbags;UnderCover tonneau cover;05 headlights;4 Hella Rallye 1000s
Quote:
Originally Posted by Smokin' View Post
The only meat pie I am familiar with usually looks pretty good in a pair of jeans.
  #4 (permalink)
Old 07-11-2008, 05:29 AM
Thank you deereman4020 and papadelogan for your knowledge that helps in my decision. So I'll keep looking for what I want. Though the truck I was looking at had 136,411 miles on it for a diesel that's nothing. Just prefer a manual trans but also wanted to know how well automatics held up to the average daily driver who doesn't haul much either but has the ability to.
__________________
98 Jeep Wrangler
  #5 (permalink)
Old 07-11-2008, 09:08 AM
Mark Kovalsky's Avatar
Mark Kovalsky has a great reputation on FTE.Mark Kovalsky has a great reputation on FTE.Mark Kovalsky has a great reputation on FTE.Mark Kovalsky has a great reputation on FTE.
Quote:
Why would the five speed auto have any better fuel economy at cruising speed? The overdrive ratio on both transmissions is 0.712:1, so there should be no difference in fuel economy at cruising speeds.
__________________
Mark
Former Ford automatic transmission engineer, 1988-2007.
  #6 (permalink)
Old 07-11-2008, 09:18 AM
mueckster's Avatar
Redneck Wrencher
mueckster has a very good reputation on FTE.mueckster has a very good reputation on FTE.mueckster has a very good reputation on FTE.
Quote:
The only advantage, I see, would be a a lesser drop in rpms between shifts due the closer gear ratios of having the extra gear. I would seem to give better pulling and acceleration torque, but the economy would basically be the same as Mark said.
__________________
-Roland-
'01 F-250 Lariat CC SB 4x4, DP Tuner, AFE II w/ Pete's Cover, ATS housing, Zoodad, SS HPX, IAH delete, 203* stat, Phantom gauges, MAP Reg, tank mods, DIY HD 4R100, 4" MBRP exh, coolant filter, shimmed FPR, Turbo Master, CCV oil trap, Procomp lift pump, CCK, TruCool, EBPV del, 140v IDM, GP LED, Foil del
PAA Member #62
  #7 (permalink)
Old 07-11-2008, 10:20 AM
Izzy351's Avatar
Master Debater
Izzy351 has a great reputation on FTE.Izzy351 has a great reputation on FTE.Izzy351 has a great reputation on FTE.Izzy351 has a great reputation on FTE.Izzy351 has a great reputation on FTE.
If you're just a daily driver, without a lot of power adders, and don't tow a lot of weight, the 4R100 should last a nice long time with proper maintenance. I am pretty much in the same boat as you -- I don't tow much and I'm only running around 310 RWHP. But, I have done the VB mods and switched to full syn fluid (Mobil1 Mercon V). The truck isn't getting driven this summer, but next spring, it will get a bigger cooler. If you do the VB mods and keep it cool and clean, it should last a nice long time.
If I towed heavy, I'd invest in an upgraded TC on top of the other mods I already listed. That really cuts down on the heat produced and increases the efficiency greatly as well (hence the heat reduction). The only variable for you is how well it was cared for previously. In my case, I saw all the maintenance records so I got a pretty well cared for truck. I bought it with 60k on it, and the tranny fluid, oil, and fuel filter changes were all documented and done on time.
Now that I've done the mods and have my tunes to match, it's like a whole new truck. I wouldn't be afraid of the auto by any means if you know it was well taken care of. If you get a real good deal on the truck, I wouldn't be afraid of it either. When the tranny goes, consider the $4k BTS/John Wood/Suncoast tranny part of the initial deal. And you'll never have to worry about the trans again. I paid 21k for mine back in Jan '07. If you get the truck for ~16k or less, you'll still be ahead of the curve, even after dropping $4k on a bullet proof tranny, IMHO.
__________________
  #8 (permalink)
Old 07-11-2008, 10:26 AM
Smokin''s Avatar
Smokin' has a great reputation on FTE.Smokin' has a great reputation on FTE.Smokin' has a great reputation on FTE.Smokin' has a great reputation on FTE.Smokin' has a great reputation on FTE.Smokin' has a great reputation on FTE.
what Joe said! After the maintenance of the truck itself has been examined, it really comes down to personal preference.
__________________
Lisa
Early '99 long bed XLT supercab. 4" Pro Comp suspension lift, 35" BFG AT's, Hypermax Boost Pyrometer, 4" turbo back exhaust setup, Hypermax 330 chip.
Quote:
Originally Posted by 87 F-150 I6 View Post
Whenever I see a prius drive by I always hear a very fant "I'm gay", its so weird
  #9 (permalink)
Old 07-11-2008, 12:28 PM
Quote:
The real advantage is launch. The TorqShift has a 3.1 first gear, the 4R100 is 2.7.
__________________
Mark
  #10 (permalink)
Old 07-11-2008, 02:07 PM
Thank you all for the help my wife is worried about there being something wrong with it since there asking 14,700 for it. Which is a little more than trade in value for an 03 F350 Crew Cab 7.3L 4spd auto FX4. I'm hoping it's just the market with the fuel prices being so high I'm sure car sales has to be down some.
__________________
98 Jeep Wrangler
  #11 (permalink)
Old 07-11-2008, 11:49 PM
mueckster's Avatar
Redneck Wrencher
Didn't know that. I wish I had one now. Good info, Mark.
__________________
-Roland-
PAA Member #62
  #12 (permalink)
Old 07-12-2008, 12:22 AM
Shade is starting off with a positive reputation.
My 03 is a six speed stick and my dad's 02 is an auto, I like the convienence of the auto but still prefer my manual. You can't race it but that's not why we have 7.3's is it? Plus if you like the low gears to play with I can put mine in 4 low and low gear and walk backwards faster than the truck will go, the speedometer won't even move but anything hooked to the truck will!
__________________
'03 7.3 ext. cab long bed XL, 6 speed, AFE stage II, MBRP 4" turbo back straight pipe, foil delete, Goodyear Silent Armors on 18" 05 King Ranch wheels. In need of lots more mods!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
