Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-10-2008, 02:57 PM
jaykup is starting off with a positive reputation.
2003-2004 F250 Crew Cab 6.0L Diesel
Looking to get the above truck, upgrading from my 2002 Ford ranger 4.0 to a Diesel. Looks like a normal price for this truck is between $12,000 to $15,000 used, with them dropping as low as $8,000-$9,000 for high mileage ones (200-250k).
Since I will probably be putting on between 5 and 10k a year, is there anything to worry about when buying a higher mileage truck of this version? Do they usually last a lot longer? Will I run into a ton of problems shortly down the road?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-10-2008, 03:11 PM
Beerstalker's Avatar
Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.
If you are looking for those years of truck most would recommend you look for a 7.3L diesel. The early 6.0L engines were much more trouble prone. The 2005-2007 6.0L had a lot less problems.
__________________
2007 F350 Lariat, CC, LB, 4x4
4.5" DR Lift w/35x12.5r20 Toyo Open Country M/Ts
Keystone Restyling Ram Air Hood W/Airaid Intake & Pre-filter
Recon Smoked Cab, Mirror, and Brake Lights
MSD Dashhawk w/A Pillar Mount
Dieselsite Coolant Filter
Lund Eclipse Window Vents
Weatherguard Toolbox
  #3 (permalink)
Old 07-10-2008, 03:28 PM
If the earlier 6.0's had problems, then would I be better off lowering my year down to 1999 or so with the 7.3L? The only reason I wanted the 2003-2004 was for the 6.0 which seemed to have more power.
Were there significant changes inside that generation?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
