Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-10-2008, 02:08 PM
jason85351's Avatar
jason85351 is starting off with a positive reputation.
Engine mounts
Does anybody know where they sell aftermarket engine mounts for an 85 351w? thanks
__________________
1985 Ford F150 351w 4x4 lift 35" BFG Mud Terrains
Finally Finished driving the truck again till november then putting her in storage
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-11-2008, 12:16 AM
Iman901's Avatar
Iman901 is starting off with a positive reputation.
Are you looking for aftermarket mounts like for an engine swap? or just OE replacements?, LMC truck probably has the OE ones.
First Reply!!!
__________________
-Ike
Henley High class of '09
'If you can teach a monkey to turn a hose on and off you can teach a monkey to grow weed.'
  #3 (permalink)
Old 07-11-2008, 07:30 AM
jason85351's Avatar
Quote:
First Reply!!!
i really want aftermarket but i can settle for oe
__________________
  #4 (permalink)
Old 07-11-2008, 09:21 AM
fellro86's Avatar
Iowa Chapter lead
fellro86 has a great reputation on FTE.fellro86 has a great reputation on FTE.fellro86 has a great reputation on FTE.fellro86 has a great reputation on FTE.fellro86 has a great reputation on FTE.
I know we carry them at Autozone, so other regular stores will have them as well. If you are looking for the poly mounts, they can be ordered either from online performance shops, or locally as well. If you are swapping, you only need to get the bases set up on the different frame.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles, holley red electric pump
the other workhorse 92 F350 2wd crew cab, 4.10 rear axle, 92 6bt Cummins, 47RH auto with Gear Vendors overdrive
the project: 77 F250 Camper special 400 4 speed
Iowa Chapter leader
Come on down and join us in the Iowa chapter, or your own local chapter!!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
