K&N air filter for 300 6 cyl?? - Ford Truck Enthusiasts Forums
Old 07-10-2008, 01:37 PM
Truxx1956's Avatar
Truxx1956 Truxx1956 is offline
Truxx1956 has a good reputation on FTE.Truxx1956 has a good reputation on FTE.
Question K&N air filter for 300 6 cyl??
Hey has anyone used a K&N air filter assembly for the 300 6 cyl? Or do they even make one? Did it help the power any?
Thanks
Old 07-10-2008, 02:41 PM
Blue Bomber's Avatar
Blue Bomber Blue Bomber is offline
Blue Bomber is starting off with a positive reputation.
what year??
the circle ones are kinda universal, but make sure you get the right height. I havn't ever used one. Kinda pricey for me.
Old 07-10-2008, 03:40 PM
Motorhead351 Motorhead351 is offline
Motorhead351 is gaining momentum as a positive member of FTE.Motorhead351 is gaining momentum as a positive member of FTE.
If your talking about an efi 4.9/300
K&N does make a replacement filter, same dimensions as stock, fits right in the air box.
Old 07-10-2008, 05:08 PM
Truxx1956's Avatar
Talking
Yes I'm talkin about an EFI 300, BUT I dont want one to fit in the box, I'd like to replace the UGLY box and make it look better and run better. I also wondered if I could change the throttle body from a V8 truck to the 6? They look the same, I'm not sure if it would bolt up or not? Has anyone done this?
Old 07-11-2008, 01:13 AM
mrgn_mtt's Avatar
mrgn_mtt mrgn_mtt is offline
mrgn_mtt is starting off with a positive reputation.
If you are talking about a complete cold air intake from K&N, I do believe that they make one, its about 200 bucks or so. Go here Performance Parts Online for Cars and Trucks - Performance Center, I think thats the website I saw them on. As far as the throttle body, the one from the 302 will be your best bet as far as fitting will be a little larger, but i don't think it will make much of a difference.
Old 07-11-2008, 06:15 AM
Well, an interesting note.
SS in a past post, mentioned he removed the air tubes completely from the throttle body, dynoed it, then compared that against a run with the tubes in tact. Made no difference.
There are universal K&N or other brand airfilters, and there is universal aluminum tubes, would imagine you could make something easy enough but how effective would it be, who knows.
All v8 throttle bodies have the same bore size, the 302/351 are identical, the 460 has extra issues that need to be addressed to fit, so go with the SBF TB. It will bolt right up with minor linkage issues to be addressed. You also have to port match your intake, more involved.
Im not sure Id tackle it for performance, as there have been guys modify carbd engines using a one barrell carb and theyd flat haul ***...so the stock TB which i believe flows 400 or so cfm, should be plenty for a hot street engine.
If you believe SS dyno experimentation, he suggested there was no vacuum at WOT on his engine, which is an old trick carbd folks used to see if they needed more carb, if vacuum is present then you need an opening that will flow more cfm, his did not.
You could read the thread right around this one titled "optis attempt at a larger throttle body".
Old 07-11-2008, 09:50 AM
SR_Crewchief SR_Crewchief is offline
SR_Crewchief is starting off with a positive reputation.
Quote:
That airbox may be ugly, but it is actually better that the K&N FIPK, provided that duct from the radiator mount to the box is intact. It is a cold air system vs the FIPK pulling in hot underhood air. If you thoughly clean the box and ducting and use good quality filters your good to go.
Don't worry about larger TB's if you haven't done any work on the head to improve air flow. The stock TB flows better than the stock unmodified head does.
Old 07-11-2008, 10:09 AM
Harte3 Harte3 is offline
Harte3 is gaining momentum as a positive member of FTE.Harte3 is gaining momentum as a positive member of FTE.
A stock Motorcraft filter will be nearly as good as the K&N and cost considerably less. For the difference in the cost I don't think there would be enough difference to make a difference in the performance.
Old 07-11-2008, 02:12 PM
Col Flashman's Avatar
Col Flashman Col Flashman is offline
Col Flashman has a very good reputation on FTE.Col Flashman has a very good reputation on FTE.Col Flashman has a very good reputation on FTE.
Not worth the cost as there is No noticeble improvement.
Old 07-11-2008, 03:54 PM
Truxx1956's Avatar
Talking
Thanks guys!!
Old 07-11-2008, 04:19 PM
There is some debate as to how well the filter, filters...
with that said, I paid a whopping $20 for my K&N replacement filter, far as Im concerned it paid for itself vs cleaning it/oiling vs paper filter scheduled replacement but now I think they are $30, so who knows...
Old 07-11-2008, 09:04 PM
6CylBill's Avatar
6CylBill 6CylBill is offline
6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.
Paid $50 for mine.. and I have to oil it. When it's time to oil it, I'm just going to replace it with a paper one. I honestly don't think it does any better than a cheapy one.
Old 07-12-2008, 06:20 AM
I didnt expect a performance increase. When I purchased mine I paid $23.
Wow...they now list for $43 local...inflation sucks hugh?
Old 07-12-2008, 07:21 PM
Silver Streak Silver Streak is offline
Silver Streak is gaining momentum as a positive member of FTE.
I considered one several years ago and they were around $50 then, I think you just got a deal.
K&N=Krappy&Nasty
Old 07-13-2008, 07:04 AM
It was around a decade ago, I was standing in the parts line, asked for a replacement paper filter, saw K&N pop up on the screen, jokingly asked, how much do they run? Dude said $23. Maybe it was luck.
87-96 5.0/5.8 Bronco/F-series K&N air filter Reed Ford Truck Parts for Sale 3 07-21-2015 03:41 PM
Diagnosing my first 6.0 big ole ford 6.0L Power Stroke Diesel 8 10-07-2013 08:01 PM
K&N filters cdntthinkofausername 1973 - 1979 F-100 & Larger F-Series Trucks 0 07-21-2012 05:25 PM
6637 mod question tj01536 1999 - 2003 7.3L Power Stroke Diesel 40 07-24-2011 10:00 AM
Air Filter for a 4.9L F150 nighthawk283 Air Intakes, Air Filters & Ram Air 5 02-17-2010 11:21 AM
Tags
1978, 300, 302, 50, 6cyl, air, body, cleaning, cyl, efi, filter, filters, ford, kn, throttle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
