Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-10-2008, 12:30 PM
Truxx1956's Avatar
Truxx1956 is gaining momentum as a positive member of FTE.
Question Pilot Bearing Removal??
Hey guys, I am changing my truck ('89 F150, 300 Cyl) from a M5OD to an automatic. I know I need to remove the pilot bearing from the crankshaft, and have been told to find a shaft that will fit snugly into the pilot bearing and pack it with greas then tap it with a hammer. Is this the right way to remove it? Or do you guys have another trick?
Thanks!
__________________
If it's worth doin, it's worth OVERDOING 1956 F100 PEGYSU
1989 F150
1956 F100 Panel truck (eventually)
1961 Unibody
2005 Taurus
2003 Suzuki Intruder 1500 LC
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-10-2008, 12:55 PM
Mark Kovalsky's Avatar
Mark Kovalsky has a very good reputation on FTE.Mark Kovalsky has a very good reputation on FTE.Mark Kovalsky has a very good reputation on FTE.
Yes, that will work. Wet toilet paper stuffed in the hole works too, and doesn't make as much of a mess.
__________________
Mark
Former Ford automatic transmission engineer, 1988-2007.
  #3 (permalink)
Old 07-10-2008, 04:04 PM
Truxx1956's Avatar
Question
Thanks man! Now I got another question for ya after I see you are a trans guru. I have a '79 model C6 and a '90 model C6, I also have a '93 AOD from a cougar. I think I want to go with a C6, between all my choices. My question for you is: Is there a difference between a '79 C6 and a '90 C6? And if I do go with the AOD, is the bolt pattern of the flywheel the same as the C6? I already have a flywheel for the C6 is why I ask.
Also if I do go with the AOD, I know I'm supposed to use a trans PSI gauge to properly adjust the TV cable, can you explain how to do that?
Thanks for all your help!!
__________________
1989 F150
1961 Unibody
2005 Taurus
  #4 (permalink)
Old 07-10-2008, 08:20 PM
rebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to behold
I use a bearing puller unless the pilot bearing is junk, in that case I use an air chisel. You can rent a puller from Advance Auto.
__________________
The Year 2008 Anno Domini -
May it bring a great year of Revelations to you.
  #5 (permalink)
Old 07-10-2008, 09:13 PM
85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.
--Pilot removal: On my '65 Mustang, I used a bolt just a little larger than the opening, and threaded it into the bronze. Once a couple threads are engaged, you can lever the bushing out. The grease/tp push out has been reported to work well here also.
--C6 vs. AOD: A '93 AOD is a good candidate, as many AOD issues had been fixed. Was this a V8? Even better. You are going to miss the OD with $5 gas...
--TV cable:
TCI AOD Throttle Valve Adjustment Instructions
Look around the TCI site for lots of AOD propaganda, parts etc, shifters, etc.
Good luck.
FWIW I'd keep the 5 gear, but then you can choose to shift for yourself on that decision....
  #6 (permalink)
Old 07-11-2008, 08:23 AM
Quote:
Yes, there are many differences. I don't know all of them.
I don't know, but I do know Ford doesn't like to keep the same bolt pattern on different applications.
See the post above this one.
__________________
Mark
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
