07-10-2008, 06:10 PM
Ok, nevermind, I got it. I decided to take a chance on breaking it and it came loose instead. Whew! If it would have broke, I would have had to pull the manifold to fix it.
I used a pipe cleaner, brake cleaner, and compressed air to clean the tube as best I can. When I blew through it with my mouth, it kinda felt like I blew a clog out.... Can't be sure though. The pipe cleaner made it easy to clean the little venturi thing in the tube.
Then I removed the EGR valve and used a syringe and some scrap tube to pull the valve open. It seems to be working properly. Can't blow thru it until the syringe opens the valve. I guess that's good. Put black rtv on it and anti-seize on the bolts and reinstalled it. Used anti-seize on everything.
Sound good?
