2003 4X4 Steering problem
07-09-2008, 06:33 AM
I just purchased a 2003 4X4 F250 Diesel. When going down the highway, I get a feeling of over steer. There seems to be a little steering wheel movement before the truck responds. I have checked the ball joints and they feel tight. The lowers are greaseable so I greased those. Someone has mentioned a steering sensor, but I haven't located that yet.
Any ideas guys would be appreciated. Thanks Jim
07-09-2008, 10:45 AM
Welcome to FTE!
Steering sensor? Maybe they meant a steering stabilizer?
Also, you may want to have your alignment checked. A bad caster angle can cause the steering to feel twitchy with no "on center" feel.
07-09-2008, 10:58 AM
Fixed caster and camber on 4x4. Can only check toe in. Haven't done that yet. Thanks for the reply. Jim
07-09-2008, 11:05 AM
on
The caster and camber on a 4x4 can be changed by shims under the springs and eccentric bushings in the ball joints. Sounds like it is need of an alignment by a good alignment shop.
07-09-2008, 11:34 AM
How's the tire pressures? What tires?
07-10-2008, 08:05 PM
on
I would check the tie rod ends. I found it worked best with one person turning the wheel and another underneath to find the problem.
07-10-2008, 08:57 PM
If an alignment shop told you the caster and camber are fixed and cannot be adjusted, run away fast.
07-11-2008, 05:55 AM
Thanks Laredo. We were under it last night and it appears tight everywhere.
There appears to be some play in the steering gear box. I think I'll make an appoint at the Dealer and have it checked. Thanks Jim
guessrow
2004 - 2008 F150
09-20-2013 08:44 PM
hammer65
1999 to 2016 Super Duty
07-28-2009 11:56 AM
hammer65
02-27-2009 05:18 PM
jimhay
04-05-2008 08:56 PM
jimmyboy
1997-2006 Expedition & Navigator
16
12-29-2007 11:04 AM
