Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-08-2008, 11:50 PM
AndysFords is starting off with a positive reputation.
Manual Pump Bypass
I have never owned a Powerstroke before, just IDI engines and on all my trucks I always bypassed the manual fuel pump and installed an electric pump, can this be done on a Powerstroke? I have had to install pumps on Powerstrokes before and its not easy, I'm not going to do anything until it goes out but I would like to know before I go to swapping it. I would prefer to do away with it.
__________________
1997 F250 Crew Cab 4x4
1988 F350 7.3 Crew Cab 4x4 Dually C6 w/ GearVendors Overdrive currently in a deep sleep until motor overhaul is finished. 1984 F250 2 wheel drive 6.9 Extended cab 4 spd manual. (3) 1976 F250 Reg Cab 4x4 All 390, two C6 and one 4 spd.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-09-2008, 02:59 AM
joe_13894 is starting off with a positive reputation.
There are two mechanical pumps.
The first is a diaphragm lift pump that pumps the fuel from the tank and puts it in the filter housing. There is a return orifice that returns fuel to the tank from the filter housing to purge air. Pressure is regulated by the diaphragm.
The second pump is a piston pump that draws from the filter and sends it to the heads. There is a pressure regulator that returns excess fuel to the filter housing.
I don't know anyone who's done it, but I don't see why it couldn't be re plumbed with one pump and setup to return from the fuel pressure regulator directly back to the tank.
  #3 (permalink)
Old 07-09-2008, 03:29 AM
westcoastslider's Avatar
westcoastslider is starting off with a positive reputation.
You could also bypass them both and get a pump strong enough to get it to the 75psi it wants.
Search for the electric pump mod.
__________________
96 F 250 185k miles, PSD, SC, LB, 5spd, 2wd (daily driver)
96 F 250 140k miles, PSD, Ext Cab, LB, Automat, 2wd (parts truck)
70 F 350 65k miles, 460, SC, 12 ft flatbed, 4spd, 2wd (occasional Sunday drives or when needed)
  #4 (permalink)
Old 07-09-2008, 06:16 AM
Cuda_jim's Avatar
<------Ancient Politician
Cuda_jim has a very good reputation on FTE.Cuda_jim has a very good reputation on FTE.Cuda_jim has a very good reputation on FTE.
There is only one mechanical pump that I know of. It lives in the engine valley. It is a 2 stage pump.....lift and pressure.
A regulated return fuel system is what you are looking for and can get pretty pricey.
Look here:
I
__________________
CLICK--> WILL WORK FOR GREEN BEANS
CLICK--> REPLACEMENT PART NUMBERS
  #5 (permalink)
Old 07-09-2008, 08:58 AM
tjbeggs's Avatar
tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.
Jim is right. You can't add a E pump to the stock system cause the fuel filter housing won't take the 70 PSI. You can rework the whole fuel system with a pump, regulator and pre and post pump filters but its either all or nothing.
__________________
Tim
Proud User of "The Cure"
1997 F-350 PSD Auto 257K
Tuned by Tony, Built by ME!
TDP/TW tunes
AD injectors
6.0 IC
17* HPOP
Tru-cool
The Cure
ESE Eliminator
6" stacks
4 Wh disc brakes
1/4 mile-14.59@88 MPH
Click the Picture for wiring diagrams, tech info and Pictures!
  #6 (permalink)
Old 07-10-2008, 01:09 PM
Quote:
Sorry, I was less than specific. Yes, they are in the same housing.
  #7 (permalink)
Old 07-10-2008, 03:09 PM
Hussler's Avatar
Hussler is starting off with a positive reputation.
Quote:
I've been thinking about this for some time. Could you not use a low pressure electric lift pump to the filter then 70 PSI electric pump to the heads?
Something like this ... sell.com classifieds : Low Pressure Electric Fuel Pump gas,diesel, marine for sale (23JR6T)
__________________
Jim
1997 F250 HD CC 4x4 7.3L - E4OD - 3.55's
EVBP Disconnected - Napa 6637 - FPR Shim
3" Down Pipe & CD - 302 Stat - 159 K Miles
The only thing I pull is the extension cord to my truck.
  #8 (permalink)
Old 07-10-2008, 03:29 PM
tjbeggs's Avatar
I am sure you could but if your going thru the work and spending the money you might as well replace the fuel bowl and regulator with better products. Or just install a SD pump and fuel filter bowl but that isn't exactly an upgrade either due to the dead headed fuel system.
__________________
Tim
TDP/TW tunes
AD injectors
6.0 IC
17* HPOP
Tru-cool
The Cure
ESE Eliminator
6" stacks
4 Wh disc brakes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
