Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-08-2008, 11:44 PM
bob wny is starting off with a positive reputation.
Smile Engine Flywheel
Hello I am new to the forum. I own a 1993 Ford F150 4x4 with a 302, automatic trans. I bought a 5 speed 4x4 setup from a 1994 F 150 with a 300 and all the research I have done I have found that everything that I got from the donor truck will interchange. I do have the 11 inch clutch assy. My question is the only part that I have found that is different is the flywheel. What is the actual difference between the two flyheels. I didnt know if the bolt pattern was different or exactly what. They both have the same 164 tooth ring gear. I dont have the automatic transmission out of the truck yet. I dont know if I need to try to locate a new flywheel before I get the truck apart. Any help would be greatly appreciated.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-09-2008, 05:36 AM
EPNCSU2006's Avatar
EPNCSU2006 has a good reputation on FTE.EPNCSU2006 has a good reputation on FTE.
You'll need a 302 flywheel from a similar year model truck (87-96). The 302 flywheel has a built-in imbalance, while the 300 flywheel has none.
__________________
Eric
'87 F150 302 manual 4sp overdrive 4x2
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
