Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1999 - 2003 7.3L Power Stroke Diesel Sponsored By:
Is F-150 Still King?
LinkBack Thread Tools
  #31 (permalink)
Old 07-17-2008, 06:18 AM
John311t has a good reputation on FTE.John311t has a good reputation on FTE.
The video of the bent push rods...
Bent Push Rods
Sponsored Links
To remove this ad, register today!
  #32 (permalink)
Old 07-17-2008, 06:29 AM
F350-6's Avatar
Slow Typing
F350-6 is a name known to allF350-6 is a name known to allF350-6 is a name known to allF350-6 is a name known to allF350-6 is a name known to allF350-6 is a name known to all
I'd say you either need a new counter top, or a set of rods.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 260,000 & counting. 6637 w/ Pete's armor. Cold air set up for 6637
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
MORE (Military Online RElay)
  #33 (permalink)
Old 07-17-2008, 06:41 AM
danskool is gaining momentum as a positive member of FTE.
How many are bent like that ?
Possible to bend back yourself with a rubber mallet,two blocks of wood and the countertop? I never tried, But my inexperience tells me it might be possible. Unless new ones are cheap.
Nice cabentry in your kitchen by the way. I won't show my wife that.
__________________
Dan
2001 F250 XLT 7.3 PSD 2wd Auto 81k miles
Foil Delete,HPX.,In tank fuel mod. Filter valve eliminate. UpFitter push buttons, TC Lockup, EBPV Brake.
  #34 (permalink)
Old 07-17-2008, 07:07 AM
Kwikkordead's Avatar
Daddy what's a sparkplug?
Kwikkordead is a splendid one to beholdKwikkordead is a splendid one to beholdKwikkordead is a splendid one to beholdKwikkordead is a splendid one to beholdKwikkordead is a splendid one to beholdKwikkordead is a splendid one to beholdKwikkordead is a splendid one to behold
That is a bent pushrod.
They have to roll perfectly flat. None of that back and forth stuff like that one is doing.
Locktight is a negotiable item IMO.
Given the track record, this needs to be a service item, retorquing the rockers and injectors.
Haven't really nailed down an interval, but until then, I'm going to call it every 20k just to be safe.
I'm going back in on my truck within the month. Going to Yellowstone with the kids in August and this needs to be done before we go.
I'll be checking the cylinder head bolts too, this time around, for curiosities sake.
__________________
Dan _ + † +
5" Exhaust
1999 F-550 4x4 ZF-6 Tow Rig
1999 VW Jetta TDI
1996 Audi A4 2.8 V6 Quattro
  #35 (permalink)
Old 07-17-2008, 07:08 AM
All 8 of them that I have pulled had a slight bend like that. I dont think its the countertops, that was the 4th counter I tried, and they all did it. Im not even going to try to rebend them, it more than likely wont work.
I can get hypermax harden rods for $325 for the set, so Im not too concerned about what the dealer is going to charge me.
__________________
Always going...
  #36 (permalink)
Old 07-17-2008, 08:43 AM
I agree this needs to be a service item, I could not believe I when I was checking the torque on them, the entire drivers side was loose.
Is just having loose rocker pedestals the reason they bend, or are there other reasons for it?
__________________
Always going...
  #37 (permalink)
Old 07-17-2008, 08:47 AM
Honestly, I couldn't answer that question. Not good enough at engineering to be able to give you a confidant answer.
They all need to roll flat though. The one in the video is scrap.
Perhaps the engine was over-revved at some point in time?
__________________
Dan _ + † +
5" Exhaust
1999 VW Jetta TDI
  #38 (permalink)
Old 07-17-2008, 09:29 AM
PaysonPSD's Avatar
Support FTE
PaysonPSD has a great reputation on FTE.PaysonPSD has a great reputation on FTE.PaysonPSD has a great reputation on FTE.PaysonPSD has a great reputation on FTE.
I know the injector hold downs are 120 in/lbs, what is the torque for the rocker pedistals?
__________________
There is a fine line between a hobby and mental illness. PAA Member 444
MORE - Military Online RElay
  #39 (permalink)
Old 07-17-2008, 09:40 AM
Quote:
20 foot pounds.
__________________
Dan _ + † +
5" Exhaust
1999 VW Jetta TDI
  #40 (permalink)
Old 07-17-2008, 11:58 AM
It might have accidently over-revved a few times.
Just called to find out how much the push rods are, $2.00 a piece lol, can't go wrong there.
__________________
Always going...
  #41 (permalink)
Old 07-17-2008, 12:04 PM
F350-6's Avatar
Slow Typing
Well you can't complain about those prices. At least things are looking up now.
__________________
Chris
  #42 (permalink)
Old 07-17-2008, 12:07 PM
just another truck's Avatar
at least momma loves me
just another truck has a good reputation on FTE.just another truck has a good reputation on FTE.
Are you pulling off the other cover?
__________________
Pat
Every man is a damn fool for at least five minutes every day; wisdom consists in not exceeding the limit.
Elbert Hubbard
PAA Member #67
Hi, My Name is Pat, and I am a Power Stroke Addict
  #43 (permalink)
Old 07-17-2008, 12:12 PM
Its already off, just ran out of time to pull the rockers off the other side, after I seen the one side is bent, I am going to replace all of them just to be safe. I hope this was all the problems with my truck, kinda odd the way it came about, one day I just heard it, it must have been there for a long time, but after the regulated return I thought it was still injector noise and passed it off. Then just recently it started to get worse, glad I caught that before something really bad could have happened.
__________________
Always going...
  #44 (permalink)
Old 07-17-2008, 12:35 PM
I kind of thought so, but I thought I would ask...
No kidding, glad it worked out this way for ya..
__________________
Pat
Elbert Hubbard
PAA Member #67
  #45 (permalink)
Old 07-17-2008, 03:46 PM
Wow only $2.00 a peice. Yup, i would not spend the time to attempt to straighten them. Not worth the time and risk. Good job finding those rods and sharing that video..
__________________
Dan
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
